Question IE8 problems
15 years 9 months ago #83088 by audisport
IE8 problems was created by audisport
Hi guys,
I'm just ending my site with JA-Anion (JA-T3 1.2.0) Template from Joomlart, Joomla 1.5.22, Kunena 1.6.2, comprofiler 1.3.1 and JCE 1.5.7.6.
Everything is working fine in Firefox. All the site is working well in Firefox, IE8, Chrome, Safari, etc...
However when I arrive at the Kunena page, I'm getting 1 layout error (ghost white box at the end of the page generated apparently by mediaboxadv.css from kunena and several javascript errors when trying to validate a message in the forum :
Message : Number expected
Ligne : 1
Caractère : 2585
Code : 0
URI : www.vagracing.ch/plugins/system/mtupgrade/mootools.js
The adress of the site where we can see this : www.vagracing.ch/forum/7-vags-srt-news/28-sdfsdfsdfds.html
Look at the bottom of the page for this strange white box, nothing appears in Firefox and for the scripts if anyone could help, I can give a member access to test it.
It's quite boring as I'm finishing the site for a publish on next week and now I have this bad surprises...
Thanks a lot for your assistance ;)
15 years 9 months ago #83090 by audisport
Replied by audisport on topic Re: IE8 problems
If this can help, the site is also quite slow, I've check the launched scripts and have all this :
<script type="text/javascript" src="/plugins/system/jcemediabox/js/jcemediabox.js?v=1013"></script>
<script type="text/javascript" src="/plugins/system/jcemediabox/js/mediaobject.js?v=1013"></script>
<script type="text/javascript" src="/plugins/system/jcemediabox/addons/default.js?v=1013"></script>
<script type="text/javascript" src="/plugins/system/mtupgrade/mootools.js"></script>
<script type="text/javascript" src="/plugins/system/jat3/base-themes/default/js/core.js"></script>
<script type="text/javascript" src="/plugins/system/jat3/base-themes/default/js/menu/mega.js"></script>
<script type="text/javascript" src="/includes/js/joomla.javascript.js"></script>
<script type="text/javascript" src=" www.vagracing.ch/components/com_kunena/j...ed/js/mediaboxAdv.js "></script>
<script type="text/javascript" src=" www.vagracing.ch/components/com_kunena/t...lt/js/default-min.js "></script>
<script type="text/javascript">
JCEMediaObject.init('/', {flash:"10,0,22,87",windowmedia:"5,1,52,701",quicktime:"6,0,2,0",realmedia:"7,0,0,0",shockwave:"8,5,1,0"});JCEMediaBox.init({popup:{width:"",height:"",legacy:0,lightbox:1,shadowbox:0,resize:1,icons:0,overlay:1,overlayopacity:0.8,overlaycolor:"#000000",fadespeed:500,scalespeed:500,hideobjects:0,scrolling:"fixed",close:2,labels:{'close':'Fermer','next':'Suivant','previous':'Précédent','cancel':'Annuler','numbers':'{$current} sur {$total}'}},tooltip:{className:"tooltip",opacity:0.8,speed:150,position:"br",offsets:{x: 16, y: 16}},base:"/",imgpath:"plugins/system/jcemediabox/img",theme:"light",themecustom:"",themepath:"plugins/system/jcemediabox/themes"});
// <![CDATA[
var kunena_toggler_close = "Cacher";
var kunena_toggler_open = "Etendre";
</script>
<link rel="alternate" type="application/rss+xml" title="Obtenir les derniers messages directement sur votre PC" href="/forum/rss.html" />
<script type="text/javascript" src=" www.vagracing.ch/components/com_comprofi.../curvycorners.min.js "></script>
<script type="text/javascript" src=" www.vagracing.ch/components/com_comprofi.../jquery-1.4.4.min.js "></script><script type="text/javascript"><!--
jQuery.noConflict();
--></script>
<script type="text/javascript" src=" www.vagracing.ch/components/com_comprofiler/js/tabpane.min.js "></script>
jQuery(document).ready(function($){
var cbshowtabsArray = new Array();
function showCBTab( sName ) {
if ( typeof(sName) == 'string' ) {
sName = sName.toLowerCase();
for (var i=0;i<cbshowtabsArray.length;i++) {
for (var j=0;j<cbshowtabsArray[0].length;j++) {
if (cbshowtabsArray[0][j] == sName) {
eval(cbshowtabsArray[1]);
return;
--></script>
Do you know if this is normal or too much ? It looks like a lot of scripts for one page...
Thanks a lot.
15 years 9 months ago #83107 by audisport
I've already found the origin of the white box at the bottom of my kunena page...It was the forum integration plugin from comprofiler...the problem now is that by desactivating this comprofiler plugin the layout come good again but users cannot see the posts in their profiles.
Regarding the script errors when validating messages, still not found anything, still bugs...
15 years 9 months ago #83735 by Drizzt99
Replied by Drizzt99 on topic Re: IE8 problems
Any news about it?
I got the same error.
15 years 9 months ago #83745 by imaaxx
Replied by imaaxx on topic Re: IE8 problems
I too have this same weird box at the bottom of the page in IE8 only, and we are using Community builder too.
Would love to get a fix for this strange issue…
Kind Regards
htaccess: Missing | PHP environment: Max execution time: 60 seconds | Max execution memory: 50M | Max file upload: 10M
Joomla default template details : team_website | author: teamwebsitehosting | version: 1.5.4 | creationdate: 03/29/08
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Installed (Version : 1.3.1) | Jomsocial: Disabled or not installed | UddeIm: Installed (Version : 2.2)
15 years 9 months ago #83776 by nbserg
Replied by nbserg on topic Re: IE8 problems
have the same problem
help plz
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 64M | Max file upload: 1000M
Joomla default template details : strip | author: NBSerG | version: 1.0 | creationdate: 2010-09-12
Kunena default template details : Blue Eagle (умолчание) | author: Kunena Team | version: 1.6.3 | creationdate: 2011-01-31
Third-party components: AlphaUserPoints: Installed (Version : 1.5.13) | CommunityBuilder: Installed (Version : 1.3.1) | Jomsocial: Disabled or not installed | UddeIm: Installed (Version : 2.1)
Time to create page: 0.172 seconds
