Question Upgraded from 1.5.9 and now I loose my Joomla sidebar.... any ideas?
16 years 2 days ago #70261 by mattlindsay
I'm loving 1.6 but now I have the following issue.....
When you go directly to the forums you have the Joomla menus on the LHS as you will see if you go to but if you click on any of the tabs ( for example, we loose the left hand menus.
Any ideas on how I can fix this?
Many thanks
Matt
16 years 2 days ago #70271 by xillibit
If i understand right, you want to disable the modules when you are into the forum pages.
So, read this doc : docs.kunena.org/index.php/How_I_can_get_..._Forum_in_my_site%3F
16 years 2 days ago #70277 by mattlindsay
Actually it's sort of the other way around... it's that I DONT want it to be full width. It's weird because under normal use, it isnt full width (the LHS sidebar is still there) but once I click on one of the tabs (New Topic for example) the Side Bar disappears. Any ideas?
Thanks for your help though
matt
16 years 2 days ago #70295 by fxstein
Matt,
This is controlled from within Joomla. Any module you want to show on the forum pages, you need to make sure that all the forum links are highlighted in the module-menu assignment.
Here is an example:
Modules are only shown on pages they are assigned to (or ALL).
Hope this helps!
16 years 2 days ago #70296 by mattlindsay
Hey, thanks fxstein, but this is how I have configured Joomla (and hence I do have the module when you go to the forum. Its only when you click one of the kunena tabs that it disappears. Have a go for yourself.
Matt
16 years 2 days ago #70297 by mattlindsay
Oh my good lord!!
OK, I hadn't realised, but when 1.6 installed, it created "sub" entries in that section (as you showed in your image). I hadn't gone back in and selected them (dont think they were available in 1.5.9). All sorted.
THANK YOU SO MUCH GUYS!!
(p.s. just a quickie.... any idea how I can remove a tab I dont want the "help" tab)
