Question Remove ALL READ
16 years 1 month ago #65038 by bigdm
Replied by bigdm on topic Re: Remove ALL READ
so... err.. any idea how i can edit this on 1.6?? defualt template (same one this site uses)
16 years 1 month ago #65043 by sozzled
Replied by sozzled on topic Re: Remove ALL READ
If you used Firebug for Firefox you would have found (within one minute) that all you need to do is modify the CSS file by adding the line (in red) below:
#Kunena .klist-markallcatsread input.kbutton {
display:none;
margin:4px;
padding:0;
16 years 1 month ago #65046 by bigdm
I do use firebug, but to be honest i wanted to remove the code not just hide it as I have no use for it within my joomla site..
Thanks for the quick relply tho, I managed to find it now
components/com_kunena/template/default/categories/listcat.php
JOB DONE :)
16 years 1 month ago - 16 years 1 month ago #65048 by sozzled
As you like - it's your website. It's really better to hide these things than to edit the source code. Editing the source code may save you a millisecond or two but could cost you hours, later, when you need to upgrade to new versions because of other issues. K 1.6.1 is just around the corner (which contains dozens of fixes to K 1.6.0) and you're only going to have to do those changes again. Then there will probably be a K 1.6.2 (and so on) and, again, you're going to have to make those changes. But, like I said, it's your website.
Last edit: 16 years 1 month ago by sozzled.
