Question Remove hard coded css styles?
16 years 1 month ago #65087 by wabugi
Thanks Matias!
I stopped working on the template for some days and just realized that the styles were still there. I was lucky that you already posted the solution for my problem ^^
16 years 1 month ago #65222 by caplinq
Hmmm... I'm having a hard time finding the file.
I checked the template.xml file in the com_kunena/template/default folder but it's not there, is it?
Also, I did a search for the initialize.php file, and it's not found either. I'm not a newbie at this, what am I doing wrong?
16 years 1 month ago #65229 by caplinq
Ok, I found it...
In the template.xml file - which is indeed here:
com_kunena/template/default/template.xml
I commented out the <params> that defined the CSS
For the initialize.php file, I don't know why i didn't find it before, it's here:
com_kunena/template/default/initialize.php
and in this file I deleted the /*Kunena Custom CSS */ details.
I don't quite iunderstand why it's here instead of in CSS file, but probably to make it easier for beginners to make basic changes.
15 years 10 months ago #82215 by WebbR
It is maybe simple for people who are not familiar with css but an option to disable it would be very helpfull. I was like serching for some time to figure out why my changes in the css did't work and then again some time to find out how to disable the custom css in the sourcecode.
Anyway Thx for the solution here in this posting!
15 years 5 months ago #97054 by marcodeluca
I dont know if there is a more recent topic for this, but I had the same questions about removing the "hard-coded" CSS styles. So, one of the answers is KIND OF right. You can disable Kunena from publishing those CSS overrides in the template details. The problem is, it's totally un-intuitive how:
In the kunena admin, under Templates, select the template you want to use and toggle this option: BLEND WITH JOOMLA TEMPLATE.
Yes = there will be no CSS overrides
No = those CSS overrides will be published.
Why you would use this label rather than something like "publish css overrides" and then have the tooltip explain what that means ( use our CSS or your templates CSS ) would make a heck of a lot more sense:)
