Question Remove hard coded css styles?
16 years 3 weeks ago - 16 years 3 weeks ago #64083 by wabugi
Hi everybody!
I've just installed Kunena 1.6 stable and I'm creating a new template based on the example template. I've found some hard coded css styles in the website header that are created by Kunena:
<style type="text/css"> <!-- /* Kunena Custom CSS */ #Kunena div.kheader { background: #5388B4 } #Kunena div.kannouncement div.kheader { background: #990000 } #Kunena div#kannouncement .kanndesc { background: #FFFFAA } #Kunena div.kfrontstats div.kheader { background: #000000 } #Kunena div.kwhoisonline div.kheader { background: #3B5323 } #Kunena .kicon-profile { background-image: url("http://MYJOOMLAURL/components/com_kunena/template/default/media/iconsets/profile/default/default.png"); } #Kunena .kicon-button { background-image: url("http://MYJOOMLAURL/components/com_kunena/template/default/media/iconsets/buttons/default/default.png"); } #Kunena #kbbcode-toolbar li a,#Kunena #kattachments a { background-image:url("http://MYJOOMLAURL/components/com_kunena/template/default/media/iconsets/editor/default/default.png"); } /* End of Kunena Custom CSS */ --> </style>
As you can see it is commented out and should be ignored by the browser. But actually it is not.
Can anybody tell me in which file I can find the code to remove it?
Last edit: 16 years 3 weeks ago by wabugi.
16 years 3 weeks ago #64089 by wabugi
Ok, I found it by myself.
The code is in the template.xml of my template ;)
16 years 3 weeks ago #64112 by severdia
They aren't actually hardcoded. You can change them in the Kunena admin and they override the CSS file. But if you don't need them, you can remove it.
16 years 3 weeks ago #64114 by fxstein
These are them template parameter. If you do your own template you can decide which ones you want as backend parameters - those you would pass like these. Set them up in the xml and load them in your own copy/version of initialize.php for your template.
Hope this helps!
16 years 3 weeks ago #64176 by wabugi
Thanks for your answers. I decided to just remove them from the template.xml because I have really no use for these parameters.
16 years 3 weeks ago #64190 by Matias
Also remove them from initialize.php (if it's not in your template, copy it into there).
The following user(s) said Thank You: wabugi
