Question Forum Images not showing
15 years 7 months ago #61964
by ke4obt
Replied by ke4obt on topic Re: Forum Images not showing
Hey sozzled,
Having never used a tag like that before I think I am in need of a sample setup please.
Thanks Flip
Thanks Flip
15 years 7 months ago #61965
Replied by sozzled on topic Re: Forum Images not showing
You can PM me the account details, if you prefer.
15 years 7 months ago #61978
by ke4obt
PM has been sent.
15 years 7 months ago - 15 years 7 months ago #61993
by ke4obt
Hey All,
Now that i've had a bit of sleep I noticed that the path to the images is wrong and I have no idea where to go to make the fix.
It seems to be looking here:
/components/com_/template/default/images/emoticons/whistling.png ..
instead of here:
/components/com_kunena/template/default/images/emoticons/whistling.png ..
Where should I look to set the correct path?
Any and all help welcome.
Thanks Flip
*edit* forgot to mention - I'm using the default template - Blue eagle - in Kunena.
instead of here:
Thanks Flip
Last edit: 15 years 7 months ago by ke4obt.
15 years 7 months ago #62297
Solution found after discussion of problem with the user. The problem involving the loss of the images was caused by the misuse of another component [reReplacer] which attempted to replace every occurrence of the string "Kunena" with "". Therefore
became
This also meant that all of the Kunena CSS template did not render (the menu appeared as a list instead of as a horizontal series of tabs, for instance).
The discussion also led to the discovery of the loss of the BBcode toolbar. This was cause by the use of a site template that completely prevented the Joomla Mootools 1.2.4 library being loaded. The site template was JS Appbox (js_app) developed by Barrie North. Despite template settings stating that it should enable mootools.js it was apparent that this template does not work with Joomla Mootools 1.2.4 and therefore it is unsuitable for Kunena 1.6
../components/com_kunena/template/default/images/emoticons/whistling.png
../components/com_/template/default/images/emoticons/whistling.png
15 years 7 months ago #62566
Working very closely with the user, we have implemented an alternative Joomla site template that works well.
The key in this case is, when selecting a site template for Joomla, make sure that you find one that states is works for Mootools 1.2.4.
