Kunena 7.0.2 Released
The Kunena team has announce the arrival of Kunena 7.0.2 [K 7.0.2] in stable which is now available for download as a native Joomla extension for J! 5.3.x/5.4.x/6.0.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 / K 6.4 and issues discovered during the last development stages of K 7.0
Solved [Resolved ] Defective Joomla template makes a mess of Kunena
13 years 10 months ago #123209 by Display
Replied by Display on topic kunena dont show good
@baaza no i dont use a gzip or rokgzipper its a clean setup
so thats not the problem.
13 years 10 months ago - 13 years 10 months ago #123212 by sozzled
Replied by sozzled on topic kunena dont show good
If you do not have the same problem with Beez20, or with the thousands of other templates that work with Kunena under Joomla 2.5.4, then the advice that's contained in My Joomla site template makes a mess of Kunena applies to you. It is not our responsibility to fix, at no cost to you, the mistakes made by a Joomla site template developer in designing a template that does not work with other Joomla extensions (such as Kunena).
If you paid for this template then you should contact the people who sold you the template and tell them "I want to run Kunena on J! 2.5.4. I can run Kunena on J! 2.5.4 using the standard Joomla (Beez20) template, but I cannot use your (Jsn Epic Pro 4.3.0) template. What can you do for me?" They may offer to fix the problem for you, they may offer to refund the money you paid for your template, or they may tell you "tough luck; you have to fix this yourself".
In a nutshell, there are your options. B)
The forum at www.kunena.org is a community-driven, self-help resource for people to ask questions and receive advice. However, this is not a place where people can expect that all problems caused by the choices they made can be resolved free of charge.
Display wrote:
I have another site with the same config only that site is from 1.6 and [it] is working ...
Would you like to show us the configuration reports from both of these sites, please?
Last edit: 13 years 10 months ago by sozzled.
13 years 10 months ago #123215 by Display
@sozzled i dont say its your or kunena's responsibility i ask for a littel help i know that the maker of the template have to help.
but i cant understand why its working on one site and the other clean site not so i think i make a fould .
refund the money has nothing to do with this problem because one site is working and one site not
so i am asking myself what do i wrong ...
here the config from the site whats working
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 16M
Joomla default template details : jsn_epic_pro | author: JoomlaShine.com | version: 4.3.0 | creationdate: 02/17/2012
Third-party components: UddeIm 2.6
Modules: Kunena Latest 1.7.1
And here the config from the site whats not working
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 16M
I dont Blame Kunena i ask only a littel help
To find MY Mistake
Peter
13 years 10 months ago #123217 by sozzled
The configuration settings in the non-working site are missing. Looks like an incomplete or defective installation of Kunena in the second site. I recommend that you uninstall Kubena, drop all the Kunena tables, and then re-install Kunena again on the non-working site. If this is a brand-new site then you have nothing to lose.
And, FYI, even though you are not using GZip or RokGZipper, there is evidence, when we look at the HTML source code, that you are using some kind of code aggregation/optimisation software. It's also possible that this other Joomla extension that you're running may be responsible for make a mess of things. The problem that we have is knowing what other Joomla extensions you're also using.
13 years 10 months ago #123220 by Display
Oke now i know where to look the config is missing .
So what you say i have nothing to lose is true but now i know where to look Thanks.
I try to reinstall kunena .
And let you know.
Thanks Peter
13 years 10 months ago #123231 by Display
I have make a clean install and the problem was still there.
So i downgrade the template and its works then i upgrade the template and it works oke now
i have contact the maker of the template and the go look for a solution
Thanks for the help
Peter
Time to create page: 0.325 seconds
