Question [Resolved] Another RokGZipper-caused total-mess-of-Kunena-styling problem
14 years 6 months ago #120968 by inf0rm3r
Hi Guys
I have been searching this forum for hours now for a solution to this and have given up, it appears there is solution but the option which corrected the issue doesn't exist in my installation/new versions of kenuna or I can't find it.
velocitytag.com/vt/index.php/forum/index
is the forum
The forum is not styling at all, not loading images, text sizes or anything.
I was told I could fix this with Use Joomla Style set to NO but I cannot find that option in the kenuna configuration anywhere or in joomla for that matter.
Any help would be appreciated as I have this forum working on a few other sites well.
14 years 6 months ago #120969 by CheechDogg
Go in template manager from your kunena control panel and turn Blend with Joomla Template off.
[img
Find me on Facebook.
14 years 6 months ago - 14 years 6 months ago #120970 by inf0rm3r
Have just tried both options on and off and it doesn't appear to change anything except the text you can see size and font.
I tried changing it to the joomla default templates and the issue remains the same also.
Thanks for your help do you have Any other ideas?
Last edit: 14 years 6 months ago by inf0rm3r.
14 years 6 months ago - 14 years 6 months ago #120972 by sozzled
The following user(s) said Thank You: Ziggy
14 years 6 months ago #120985 by CheechDogg
I just noticed that your template is a RocketTheme template which are very notorious for causing problems with Kunena. There is always something that conflicts with Kunena when using Gantry, RocketTheme's template framework.
I am sure you have a premium membership with RocketTheme right? You might want to contact them about this and have them suggest something to fix it.
[img
14 years 5 months ago - 14 years 5 months ago #121097 by Evopro
Hi
I have the same problem and yes, I use a rocket theme template with Gantry. There are very many of us that do - could anyone that have worked on a fix let us know what to do about this?
Changing the setting "Blend with Joomla Template" only marginally changes this basic horror show.
Best Regards
Johan Niklasson
Last edit: 14 years 5 months ago by Evopro.
Time to create page: 0.215 seconds
