Question Squashed Top Menu Display
14 years 9 months ago #117628 by thexclub
You reply very quickly, thanks.
14 years 9 months ago #117629 by thexclub
I have posted login details and a link that will force the error (I think)
14 years 9 months ago #117630 by thexclub
I have upgraded to 1.7.2
htaccess: Exists | PHP environment: Max execution time: 120 seconds | Max execution memory: 512M | Max file upload: 32M
Joomla default template details : running | author: JoomlArt.com | version: 1.2.1 | creationdate: June 2011
Kunena default template details : Example Template | author: Kunena Team | version: 1.7.2 | creationdate: 2012-01-31
Plugins: System - Mootools Upgrade: Enabled | System - Mootools12: Disabled | Kunena Search 1.7.1 | Kunena Discuss 1.7.1
Modules: Kunena Latest 1.7.1 | Kunena Stats 1.7.1 | Kunena Login 1.7.1 | Kunena Search 1.7.1
14 years 9 months ago - 14 years 9 months ago #117631 by sozzled
Would you like to remove the module (that works around the problem) first, please. Then I can see the site the way you started. Unless that's the way you want to display your forum page, of course, in which case there's nothing to fix.
I would like to see the situation as you first reported it. Thanks.
Last edit: 14 years 9 months ago by sozzled.
14 years 9 months ago - 14 years 9 months ago #117633 by thexclub
I removed the spacer Module before I sent user details
Try this link removed.
With the spacer module (2 p tags & hr tag) published you can see the page display error anyway. When the page loads correctly the HR is down from the user menu and when the error page is loaded the hr mover up accordingly.
But I have un-published it.
Last edit: 14 years 9 months ago by thexclub.
14 years 9 months ago #117635 by sozzled
Resolved by workaround
Time to create page: 0.150 seconds
