Kunena 6.4.13 Released
Question Kunena Module Positions doesn't gets created
14 years 10 months ago #107895 by K0mmaT1A
I have searched everywhere but I can't find a solution to this problem...
I have a joomla 1.7 installation, with kunena 1.7.
I did a fresh install, never used kunena before this version, so it was clean install.
When I've installed kunena 1.7, kunenamenu was created (it was empty), but the problem is that the module position doesn't gets created, so I can't make the kunena menu appear on the forum (kunena_* doesn't appear on the list of module positions)
I've tried reinstalling the kunena, same luck nothing changed.
I have debug on, and no problems appears.
The site is here www.techclub.gr/forum.html
Anyone can help? tried everything...
The topic has been locked.
14 years 10 months ago - 14 years 10 months ago #108212 by K0mmaT1A
I got it,
but maybe someone should have wright in the instructions how to add the lines in templateDetails.xml :angry:
Last edit: 14 years 10 months ago by K0mmaT1A.
14 years 10 months ago #108542 by DJ
Could you provide the directions you found? I'm having the same problem, but can't seem to figure it out?
14 years 9 months ago - 14 years 9 months ago #108798 by K0mmaT1A
Go here \templates\*yourtemplate*\ and open your templateDetails.xml
add there these lines
<position>kunena_profilebox</position>
<position>kunena_announcement</position>
<position>kunena_bottom</position>
<position>kunena_msg_1</position>
<position>kunena_menu</position>
<position>kunena_section_1</position>
<position>kunena_topic_1</position>
etc...
then go to components -> kunena forum -> create menu and voila.
But really guys, this procedure MUST BE AUTOMATED, your are loosing tons of users,
or a least provide a howto.txt with the zip..
Last edit: 14 years 9 months ago by K0mmaT1A.
14 years 9 months ago #108803 by DJ
I'm just a novice and thought I could benefit from that; however, in the meanwhile, I was able to get it working the way I wanted. Thanks much as I'm sure others could use it!
14 years 9 months ago #109148 by Matias
This cannot be fixed by us as it's something that needs API in Joomla. And no, we are not going to modify files for each template from Kunena.
Time to create page: 0.227 seconds
