Question Kunena Module Positions doesn't gets created
15 years 1 week ago #107895
by K0mmaT1A
Kunena Module Positions doesn't gets created was created by K0mmaT1A
I have searched everywhere but I can't find a solution to this problem...
I have a joomla 1.7 installation, with kunena 1.7.
I did a fresh install, never used kunena before this version, so it was clean install.
When I've installed kunena 1.7, kunenamenu was created (it was empty), but the problem is that the module position doesn't gets created, so I can't make the kunena menu appear on the forum (kunena_* doesn't appear on the list of module positions)
I've tried reinstalling the kunena, same luck nothing changed.
I have debug on, and no problems appears.
The site is here www.techclub.gr/forum.html
Anyone can help? tried everything...
The topic has been locked.
15 years 1 week ago - 15 years 1 week ago #108212
by K0mmaT1A
Replied by K0mmaT1A on topic Re: Kunena Module Positions doesn't gets created
I got it,
but maybe someone should have wright in the instructions how to add the lines in templateDetails.xml
Last edit: 15 years 1 week ago by K0mmaT1A.
15 years 22 hours ago #108542
by DJ
Replied by DJ on topic Re: Kunena Module Positions doesn't gets created
Could you provide the directions you found? I'm having the same problem, but can't seem to figure it out?
14 years 11 months ago - 14 years 11 months ago #108798
by K0mmaT1A
Go here \templates\*yourtemplate*\ and open your templateDetails.xml
add there these lines
<position>kunena_profilebox</position>
<position>kunena_announcement</position>
<position>kunena_bottom</position>
<position>kunena_msg_1</position>
<position>kunena_menu</position>
<position>kunena_section_1</position>
<position>kunena_topic_1</position>
etc...
then go to components -> kunena forum -> create menu and voila.
But really guys, this procedure MUST BE AUTOMATED, your are loosing tons of users,
or a least provide a howto.txt with the zip..
etc...
Last edit: 14 years 11 months ago by K0mmaT1A.
14 years 11 months ago #108803
by DJ
I'm just a novice and thought I could benefit from that; however, in the meanwhile, I was able to get it working the way I wanted. Thanks much as I'm sure others could use it!
14 years 11 months ago #109148
by Matias
Replied by Matias on topic Re: Kunena Module Positions doesn't gets created
This cannot be fixed by us as it's something that needs API in Joomla. And no, we are not going to modify files for each template from Kunena.
Time to create page: 0.262 seconds
