Question Forum Margins
15 years 3 months ago - 15 years 3 months ago #104898 by big_d83
Forum Margins was created by big_d83
The margins of my forum are extending further than I would like them to. I noticed that this was a result of the number of pages a particular post has. Is there a way to limit the number of pages that can be clicked?
Example on one of my pages it goes: Pages 1 2 3 4 5 6...14
I would like it to be more like: Pages 1 2 3...14
That would significantly reduce the overall width of my forum
This is the link to the particular thread I am asking about
mark.raphaelproductions.com/index.php/fo...ions/146-random-chat
htaccess: Exists | PHP environment: Max execution time: 50000 seconds | Max execution memory: 90M | Max file upload: 40M
Joomla default template details : ja_opal | author: JoomlArt.com | version: 1.0.1 | creationdate: 04 June 2010
Kunena default template details : KProSilver | author: ExtensionTemplates.com | version: 1.6.2 | creationdate: 2011-01-01
Third-party components: CommunityBuilder 1.7 | UddeIm
Last edit: 15 years 3 months ago by big_d83.
15 years 3 months ago #104900 by sozzled
The following user(s) said Thank You: big_d83
15 years 3 months ago #104907 by big_d83
Replied by big_d83 on topic Re: Forum Margins
Thanks, but I do not have access to view that page.
15 years 3 months ago #104910 by sozzled
Replied by sozzled on topic Re: Forum Margins
Sorry. That was my mistake. Here are two other links that you should be able to access that contain the information you're looking for:
15 years 3 months ago #104912 by big_d83
So if I go through and change the file on my PC and then upload it back into Joomla, will I also have to reset the rest of my files? Or is there a way I can access it through the Joomla admin page to adjust the view.php file?
15 years 3 months ago - 15 years 3 months ago #104913 by sozzled
As far as I know, and I haven't tested the code myself, it should be possible to make this change in the way you described. No, you can't make the change by using some GUI-driven means in the Joomla backend. You need to change the software.
Alternatively (and this may be a simpler solution) you could use a different Joomla site template that allows more room to display the component. To some extent, this comes into the topic I created Which came first? The template or the forum? Different Joomla templates allows varying amounts of space for things and, depending oin the template you choose, some things work well and other things don't.
Kunena produces a lot of data. The Kunena Blue Eagle template was designed for the "lowest common denominator", namely a monitor size of around 800 x 600 px - we could have an interesting discussion whether that is what most people use these days - and consequently it fits nicely if your template allows about 780 px to display the component. Kunena will fit in narrower templates but not always and not necessarily without having to make certain compromises. In other words, if the forum, itself, is a main feature (or the main feature) of your website, it may be better to find a Joomla template that displays it in a more flexible way that what is allowed by the template that you choose in designing your website.
Last edit: 15 years 3 months ago by sozzled.
Time to create page: 0.164 seconds
