Question narrower
My joomla site is not across the board and when I open the forum, this is not nice, so I would possibly also in the forum narrower, if possible.
If possible how can I do that?
These problems are invariably the caused by the site template that you are using. See How I can get the full width for Kunena Forum in my site? as one possibility.
If you install Firebug for Firefox you will be able to pinpoint exactly what is causing your problems. Does this help?
I use the standard template
I don't think you want the forum narrower. I think you want your forum wider. I could be wrong but we really need to see your website to appreciate the issues that you appear to be having.
