Idea Template Not Displaying
15 years 11 months ago - 15 years 11 months ago #74491 by sozzled
Replied by sozzled on topic Re: Template Not Displaying
tanlara: Your website loads 18 Javanscript libraries - I think this must be an all-time record high! I don't think I've seen any website load as many Javascript libraries before. It's a wonder that anything works on your website. For example, your "Groups" menu item does not work, either.
Eliminate as many of these Javascript library references as possible. Start with the Javascript libraries that are loaded last as work your way back. In your case I think you may require dedicated professional help.
Last edit: 15 years 11 months ago by sozzled.
15 years 11 months ago #74766 by tanlara
Replied by tanlara on topic Re: Template Not Displaying
But it is working in localhost.
15 years 11 months ago #74769 by sozzled
tanlara: I believe you! Your website works great on you PC and the 18 Javascript libraries or the Rockettheme template or the webhosting platform and the dozens of other add-ons, modules, plugins, components, etc. may be totally irrelevant.
What are you trying to achieve with that much level of complexity?
Can you please provide your K 1.6 configuration report. Thank you.
15 years 11 months ago #75592 by smichaelmoore
I tried a different, non-Rockettheme template, but I didn't completely uninstall the Rockettheme template. I will try it. Is there a known issue with Kunena and Rockettheme?
15 years 11 months ago #76509 by smichaelmoore
OK...I found the culprit. It was the RokGZipper plugin causing the issue.
15 years 11 months ago #76534 by sozzled
I'm very glad that this issue is fixed for you. I won't write "I told you so" ... (forget that you just saw that I did). ;)
