Idea Template Not Displaying
16 years 1 week ago - 16 years 1 week ago #71289 by smichaelmoore
For some reason (that I am undoubtedly overlooking) my Kunena 1.6.1 template is not loading. I have tried the default and several others, none are working. I have searched the forum but didn't see an issue similar to mine. The issue can be seen here: www.basinscene.com/Rocketlauncher/index....w=listcat&Itemid=216
[attachment:1]C:\fakepath\ScreenHunter_01 Nov. 22 16.06.gif[/attachment]
Here is my config:
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 64M | Max file upload: 8M
Joomla default template details : rt_omnicron_j15 | author: RocketTheme, LLC | version: 1.5.2 | creationdate: November 16, 2010
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Installed (Version : 1.2.3) | Jomsocial: Disabled or not installed | UddeIm: Installed (Version : 2.1)
Plugins: System - Mootools12: Disabled | System - Mootools Upgrade: Enabled | JFirePHP: Disabled or not installed | Kunena Discuss: Enabled (Version : 1.6.0-RC2) | Kunena Search: Disabled or not installed | My Kunena Forum Menu: Enabled (Version : 1.6.0-RC1) | My Kunena Forum Posts: Enabled (Version : 1.6.0-RC1)
Modules: Kunena Latest: Enabled (Version : 1.6.0-RC2) | Kunena Stats: Enabled (Version : 1.6.0-RC2) | Kunena Login: Enabled (Version : 1.6.0-RC2)
Last edit: 16 years 1 week ago by smichaelmoore.
16 years 1 week ago #71316 by sozzled
Replied by sozzled on topic Re: Template Not Displaying
Refer to the image in Kunena 1.6 Template - Skinner - Preview (msg #32).
Set Blend with Joomla Template = No
16 years 1 week ago - 16 years 1 week ago #71318 by smichaelmoore
Thanks sozzled, unfortunately, that affected onlytext color, but did not fix the issue.
16 years 12 hours ago #72152 by smichaelmoore
So has no one else had this problem?
16 years 12 hours ago #72155 by sozzled
Have you tried a different site template (I mean completely uninstall and remove the template and any plugins that came with it) just to establish that the Rockettheme template is not responsible for this problem?
15 years 11 months ago #74489 by tanlara
Replied by tanlara on topic Re: Template Not Displaying
Its same for me... working great at localhost :(
link: www.mycampusin.com/mycampusin/beta/
Please some one help me...
