Question Why did 1.6.1 change my link colour (and how to fix it?)
15 years 10 months ago #71180 by severdia
You would see the Template Manager under the Extensions menu. If you can't see it, you're not a Super Administrator. You need to log in with another account that already is a Super Admin and/or upgrade the account you usually log in with. Or you may need your Super Admin to upgrade your account for you if you're not the main Super Admin on your test site.
The topic has been locked.
15 years 10 months ago #71527 by bigmike0601
Severdia,
Thanks for your help, but I have one more question. I want to keep the link color of the categories white, but change all the others. The code you gave me changed them all including the category links.
Thanks!
Mike
15 years 10 months ago #71533 by severdia
Did you check out this topic?
www.kunena.org/forum/170-k-16-templates-...y-kunena-16-template
There's a CSS block there with comments next to each part so you can pick and choose what you want to change.
The following user(s) said Thank You: pickykim
15 years 10 months ago #71539 by bigmike0601
Yes, I looked at it. However, I don't see where to seperate the forum header (categories) links colors from all the other links. Here is the template I want to copy: www.easternshoreman.com . This is my live site running K1.5.11, but before I upgrade I need to make sure the template will match.
You see the links are all green except the forum headers are white.
15 years 5 months ago #92594 by pickykim
Thanks for all the help. You are very patient. If you have time, can you tell me where I would change the font of the main HI categories? It used to show up as my template font Segoe Script but now it is just some sort of default Tahoe or something. Jeesh, between modifying the joomola template, modifying the jomsocial template and modifying the kunena template, I'm going bonkers. Though I must say JomSocial is on my hate list right now. One other quick question. I know Kunena 1.6.3 came with alpha user points. however, once i upgraded to jomsocial 2.2, i cannot use them. Is this something I need to ask about here at kunena, at jomsocial (which would be a joke) or alphauserpoints people? Thanks! Kim :)
15 years 5 months ago #92599 by sozzled
pickykim wrote: Can you tell me where I would change the font of the main HI categories? It used to show up as my template font Segoe Script but now it is just some sort of default Tahoe or something. Jeesh, between modifying the joomola template, modifying the jomsocial template and modifying the kunena template, I'm going bonkers.
You might find the article Which came first? The template or the forum? interesting reading in relation to your observations.
You can solve most of these template issues - these CSS issues - yourself if you use the web design tools that come with your browser (or download and install Firebug for Firefox ) and the article Firebug in the Wiki will show you how. You can then add your own CSS styles to your Joomls site template file.
pickykim wrote: One other quick question. I know Kunena 1.6.3 came with alpha user points. however, once i upgraded to jomsocial 2.2, i cannot use them. Is this something I need to ask about here at kunena, at jomsocial (which would be a joke) or alphauserpoints people?
No version of Kunena installs Alpha User Points. AUP is a separate Joomla extension that you have to download and install yourself. K 1.6 has configuration options that allow you to integrate AUP with your Kunena forum. I hope that answers your question.
Time to create page: 0.263 seconds
