The way i understand it is that there there really isn't a Kunena template, so much as a structure for controlling the appearance of your Kunena forum. You then modify your site's template to override the defaults. In my case i have a template for the whole site with a master CSS file called template.css. When i want to change Kunena i add a line to that file and leave the Kunena template files untouched. You CAN change those files, but i think that's asking for trouble. Whatever changes you put in your site's template will override the defaults anyway.
There's a line in the Kunena template that says something like this:
/* This line sets the color for every other row in the list of threads */
#Kunena tr.krow2 td {
background: none repeat scroll 0 0 #333333 !important;
It probably has some other number in there. But if that's the element you want to change, copy the text, paste it in your site's main template and change away. Firebug will let you see what the change will do before you do it. The only thing i dislike about Firebug is that you can't copy from it (as far as i can tell).
Firebug will tell you which file and which line is dictating the color of the text and anything else. i highly recommend playing with it until you start seeing how it all works. Play in Firebug first. Turn lines on and off, tweak the variables. Then start on your template. By working through it you'll learn quite a bit. Use comments to tell yourself what changes you are making.
i think the line for text color looks something like this:
color: #000 !important;
Kunena defaults to black text on white.
This is what i did in my template.css to make things dark and pretty. i still have some work to do. Note me talking to myself in the comments.
/* Change the link colors */
#Kunena a:link,
#Kunena a:visited,
#Kunena a:active {
color:#XXXXXX !important;
/* Change the header background colors */
#Kunena .kblock div.kheader {
background:none repeat scroll 0 0 #000000;
/* Change the header text colors */
#Kunena .kblock div.kheader h2 a:link,
#Kunena .kblock div.kheader h2 a:visited,
#Kunena .kblock div.kheader h2 a:active {
color: #fff !important;
/* Change the tab colors */
div#ktab ul.menu li a {
background-color: #444444 !important;
/* Change the active tab & rollover colors */
div#ktab li#current a {
div#ktab ul.menu li a:hover {
background-color: #YYYYYY !important;
/* Change the border color under the top nav */
#Kunena #ktop {
border-color: #YYYYYY;
/* Change the pagination color */
#Kunena .kpagination .active {
background:none repeat scroll 0 0 #XXXXXX;
border:1px solid #YYYYYY;
#Kunena .kpagination a {
border:1px solid #000000;
#Kunena .kpagination a:hover {
border:1px solid #YYYYYY ;
background: #XXXXXX;
/* Change the post link color */
#Kunena div.kmsg-header h2 a {
/* Change the toggler color */
#Kunena #ktop span.ktoggler {
background-color:#444444;
/* Change the button rollover color */
#Kunena .kbutton:hover, #Kunena .kbutton:focus {
background-color: #XXXXXX;
/* This line turns kunena text black. Turning that off so the text will be white again.
#Kunena {
color: #000000;
/* Sets the thread title background color */
#Kunena tr.krow1 td {
background: none repeat scroll 0 0 #222222 !important;
/* Sets the alternating thread title background color */
/* sets the background color of the threads! */
#Kunena div.kblock {
background: none repeat scroll 0 0 #000000 !important;
/* Not sure what this does yet */
#Kunena .krow2-stickymsg {
#Kunena .krow1-stickymsg {
#Kunena td.kprofile-left {
#Kunena .kwho-globalmoderator {
color: #FFFFFF !important;
font-weight: bold;
/* attempt to fix quoted text background */
#Kunena div.kmsgtext-quote {
/* The box showing the path in the forum */
#Kunena .kforum-pathway {
color: #ffffff;
/* The header description */
#Kunena div.kfheadercontent {
color: #ffffff;
