Question customising example template
16 years 1 month ago #64182 by woonydanny
okay i need some help,
I am customising the default template to my own liking. so i copied the example template and am now customising the css files but i want to know what the right way to do it is.
why is there a file kunena.forum-min.css? and this is painful to edit as it is all in one paragraph. but it seems that the site is using this as the dominant css and if i change stuff in the template's kunena.forum.css nothing changes.
surely there is a better way to do this?!...
still wish that i can write my forum signature through a jomsocial plugin and do it from my jomsocial profile :(
16 years 1 month ago #64191 by Matias
There should be article in our wiki on the subject, but I'm currently too tired to look where it is.
Anyway this is how you do it:
1) Enable Debug in Forum Configuration (First tab)
2) Edit kunena.forum.css as much as you wish
3) When ready, minimize kunena.forum.css with online tool like ( developer.yahoo.com/yui/compressor/ )
4) Disable debug
Minimized files make your site faster to load -- but the files are hard to read.
16 years 1 month ago #64307 by woonydanny
Matias wrote: There should be article in our wiki on the subject, but I'm currently too tired to look where it is.
4) Disable debug
yes thought that was the case, but was wondering why there was both files there. in anycase i will change the main css file then as you say just minimise it.
thanks for the help :)!!
16 years 1 month ago - 16 years 1 month ago #65888 by Tom01
where can I change the text color from gray to black? kunena.forum.css file or kunena.forum-min.css? at which position is this?
It's hard to read for users (gray text on white background).
thanks
Last edit: 16 years 1 month ago by Tom01.
  • Nihil
  • Nihil's Avatar
  • New Member
  • New Member
16 years 1 month ago #65890 by Nihil
16 years 1 month ago #65892 by Tom01
thank you for this tip.
is it correct that the 1.6 kunena template uses the same text-color like the joomla-page?
is it possible that the kunena-template uses a different text-color as the joomla-mainpage?
there are different designs in use.
great thanks
