Merged [Merged topic] How to add topic icons
15 years 6 months ago #91398 by sozzled
See msg #2 in this topic. The procedure is explained here.
15 years 4 months ago #99462 by dirkovision
in the latest 1.6.4 release the icon.php file can be found in the:
../components/com_kunena/template/default
directory..
15 years 3 weeks ago - 15 years 3 weeks ago #108448 by Yxos
Replied by Yxos on topic Re: How to add more topic icon
dirkovision wrote: in the latest 1.6.4 release the icon.php file can be found in the:
directory..
It's called icons.php, and it's located the same place in 1.7.0 B)
Indeed it is very easy to add more file names to the array and to provide more icons to the icons library.
I assume this is the reason why no option has been implemented to manipulate those icons in the Administration, like it is for the icons to be used with a forum post...
I can live with this :)
/Yxos, Kunena Translator, da-DK.
Overvej at abonnere på kategorien www.kunena.org/forum/48-Danish
Last edit: 15 years 3 weeks ago by Yxos.
The following user(s) said Thank You: dirkovision
14 years 10 months ago - 14 years 10 months ago #114053 by janaf
Replied by janaf on topic [Solved] Add more Topic icons
How can I add more topic icons to the editor?
I would like to add a "Check mark" or "OK stamp" for solved / closed / replied topics.
Last edit: 14 years 10 months ago by janaf.
14 years 10 months ago - 14 years 10 months ago #114056 by sozzled
Replied by sozzled on topic Re: Add more Topic icons
Please, this question has been asked and answered more times than I can remember. If you search the forum for add topic icon you will find the answer.
Last edit: 14 years 10 months ago by sozzled.
The following user(s) said Thank You: janaf
14 years 10 months ago #114057 by janaf
Replied by janaf on topic Re: Add more Topic icons
No offence but I DID make a search before asking. It returned 430 replies, unrelated, so I did not find what I wanted. Going through them again, only a couple of them where about Topic icons, first one on page 10?
But I got it now:
Add icons to /components/com_kunena/template/default/images/icons/
edit-add the filenames to /components/com_kunena/template/default/icons.php
