Question How to change text color, background, and border on quoted text
14 years 7 months ago #118689 by wallstreetamigo
Thanks sozzled! So busy with the site that I didn't even notice the Kunena update!
As for the quoted text area background, in a perfect world it would be similar to what pops up when you click on Quick Reply. I believe this is done through a transparent PNG so I'm not sure how to do that. If it is possible that would be the best solution. If it is a solid color, just making the area a little bit lighter than the existing transparency there would probably work ok.
For lettering, it will depend a little bit on the background but we would like to use #4488ff or something close to it. It is the same color we used for the "Global Moderator" legend color.
14 years 7 months ago #118691 by sozzled
So, you want to add the following lines to the end of your Joomla site template CSS file:
#Kunena div.kmsgtext-quote { background-color: rgba(128, 128, 128, 0.4); border: 1px solid #4488FF; color: #4488FF; }
And you should be good to go.
I will be happy to answer any more questions on this topic for the fair price of AUD 10.00 per question. Thank you. ;)
Time to create page: 0.295 seconds
