Question Template issues,
15 years 1 month ago - 15 years 1 month ago #108431 by Athunder
Replied by Athunder on topic Re: Template issues,
xillibit wrote: Are-you using Kunena 1.7.0 actually ?
If, yes you downgrade to 1.6.5 this shouldn't causing issues, but make a backup before downgrade to be to don't break anything.
I just found out that the gk template is made for vesion 1.6.3, so downgraded it all the way down, but it solved nothing :(
Can you please have a look at my forum
I want the forum stats moved in the empty space, just as Kunena site has it.
www.afgcric.com/List-forums/List-forums/
Also this profile page should display proper,
www.afgcric.com/868-Spinghar/
and off course there is still the button issue :(
Last edit: 15 years 1 month ago by Athunder.
15 years 1 month ago #108813 by Athunder
xillibit, any solution?
15 years 1 month ago #108814 by kiwi3685
Replied by kiwi3685 on topic Re: Template issues,
Athunder, surely if you have a problem with a non-standard template you should be asking the template creator to fix it's problems, not the Kunena developers?
