Question Template issues,
15 years 1 month ago - 15 years 1 month ago #108005 by Athunder
Template issues, was created by Athunder
Hi every,
I've quite a few issues with my template, there a few things which are not working or are little bit misplaced. I'll add screenshot of each of them, hope someone can help me out..
My buttons look like that, totally misplaced
Also the stats are annoying me, I them want moved up into the empty space..
Last edit: 15 years 1 month ago by Athunder.
15 years 1 month ago #108017 by Athunder
Replied by Athunder on topic Re: Template issues,
The editor toolbar issue was solved by enabling the mootools
15 years 1 month ago #108144 by Athunder
Two days without any replay, Have I posted in the wrong section?
15 years 1 month ago #108145 by xillibit
Replied by xillibit on topic Re: Template issues,
Which Kunena template are-you using ?
15 years 1 month ago - 15 years 1 month ago #108379 by Athunder
I used reddy, but removed that now, and now using Gavick Musicity Template,
but still got some issues as above...
I've quite a few posts now, can I downgrade Kunena to 1.6 so the templates works properly...
15 years 1 month ago #108383 by xillibit
Are-you using Kunena 1.7.0 actually ?
If, yes you downgrade to 1.6.5 this shouldn't causing issues, but make a backup before downgrade to be to don't break anything.
Time to create page: 0.145 seconds
