Important J! 1.6.3: No Italian language in K 1.6.4 causes loss of BBcode toolbar
15 years 3 months ago - 15 years 3 months ago #97612 by AnyWay
After I upgraded my J1.6 site from K1.6.3 to K1.6.4 I cannot view the "BBCode bar", with bold etc...
Somebody know the reason?
Mootools seems loaded:
<script src="/media/system/js/mootools-core.js" type="text/javascript"></script>
<script src="/media/system/js/mootools-more.js" type="text/javascript"></script>
Thank you very much.
Last edit: 15 years 3 months ago by sozzled. Reason: Changed title to improve relevance for search purposes
15 years 3 months ago - 15 years 3 months ago #97616 by sozzled
It is uncommon for J! 1.6 users to encounter these problems because, one would expect, most other Joomla extension developers should have fixed their software so that they do not load other software that clobbers Joomla. In other words, as we have written on several hundred occasions in the past, these problems are not caused by Kunena but are caused by the software soup that resulted from the choice of other extensions you have installed.
Having said that, the solution is still the same. [strike]Please read msg #1 in this topic[/strike].
Last edit: 15 years 3 months ago by sozzled. Reason: Topic split
15 years 3 months ago #97619 by AnyWay
Thank you for your reply, but I haven't installed any new extension before upgrading to the last version of Kunena (and before it was working).
I'm using only CB 1.4 + Uddeim + Funlite template.
Any idea on what I can check on J1.6?
15 years 3 months ago #97621 by sozzled
Funlite template? Who designed or developed that extension? What other Javascript libraries are installed by that extension (or any other extension that you might have installed)? These are the clues. This is what you need to look for. Again, the information posted in msg #1 in this topic is what you need to use.
15 years 3 months ago #97623 by AnyWay
Funlite is developed by Joomlapolis: www.joomlapolis.com/joomla-templates
I have no other 3rd extensions/plugin installed.
15 years 3 months ago #97624 by sozzled
Do you have any issues if you uninistall the Funlite template and use one of the standard Joomla templates?
Time to create page: 0.217 seconds
