Question Multi-lingual website - Forum moderation gives HTTP 500 errors
You should not be getting HTTP 500 error messages at all. Diagnosing HTTP 500 internal server messages is tricky. You need to enable Joomla debug mode and you need to set error reporting to maximum and look in the Apache error logs to see what's going on.helene wrote: When the moderator moderates something the [moderator received a HTTP 500 error] message ... If I ... click on the link to the homepage, I do ... correctly [return] to the Frontpage and [my] changes [are effected]. But I dont understand why I have to go around this way.
It looks to me like a Joomla problem. It looks like the problem is complicated because it's a multi-lingual website. I don't know enough about how to setup multi-lingual websites and what provision you need to make for .htaccess files and so on and so forth or whether these things might even be involved.
Maybe someone else in the community might have some tips for you.
What you say I should do with enabling debug mode and look into error logs
I am not too happy with it ...
But anyway, thanks for your help and say hello to Canberra from me ... even though I am from Denmark, Canberra is another base of mine .. every now and then.
kind regards Helene
Thanks Kunena for the nice extension!
Unfortunately I have the same problem...
I am using multilingual (Joomfish 2.1.6 (Twinkle)) Joomla 1.5.23 with JA Purity template and Kunena 1.6.4 4832 [ Kerkrade ]
Here is the debug info, if it helps:
500 - ??No valid database connection:??
•You may not be able to visit this page because of:•
•an out-of-date bookmark/favourite•
•a search engine that has an out-of-date listing for this site•
•a mistyped address•
•you have no access to this page•
•The requested resource was not found.•
•An error has occurred while processing your request.•
•Please try one of the following pages:•
•Home Page•
•If difficulties persist, please contact the System Administrator of this site.•
Call stack
# Function Location
1 JSite->dispatch() ***/public_html/forum/index.php:68
2 JComponentHelper->renderComponent() ***/public_html/forum/includes/application.php:124
3 require_once() ***/public_html/forum/libraries/joomla/application/component/helper.php:162
4 KunenaApp->__construct() ***/public_html/forum/components/com_kunena/kunena.php:881
5 CKunenaPost->display() ***/public_html/forum/components/com_kunena/kunena.php:496
6 CKunenaPost->domoderate() ***/public_html/forum/components/com_kunena/funcs/post.php:1076
7 CKunenaModeration->move() ***/public_html/forum/components/com_kunena/funcs/post.php:630
8 CKunenaModeration->_Move() ***/public_html/forum/components/com_kunena/lib/kunena.moderation.class.php:429
9 CKunenaModeration->_Move() ***/public_html/forum/components/com_kunena/lib/kunena.moderation.class.php:205
10 CKunenaTools->reCountBoards() ***/public_html/forum/components/com_kunena/lib/kunena.moderation.class.php:253
11 JFDatabase->query() ***/public_html/forum/components/com_kunena/class.kunena.php:266
12 interceptDB->setRefTables() ***/public_html/forum/plugins/system/jfdatabase/jfdatabase_inherit.php:642
13 interceptDB->_getFieldCount() ***/public_html/forum/plugins/system/jfdatabase/intercept.jdatabasemysql.php:225
14 JError->raiseError() ***/public_html/forum/plugins/system/jfdatabase/intercept.jdatabasemysql.php:79
15 JError->raise() ***/public_html/forum/libraries/joomla/error/error.php:171
16 JException->__construct() ***/public_html/forum/libraries/joomla/error/error.php:136
I will be grateful to anyone who had this problem and found a solution.
Thank you for your question and for posting the stack trace of your HTTP 500 Internal Server error but your problem is different to the previously-asked question. In your case, you have a database connection issue.
Please read the posting guidelines printed at the top of this page and, in particular, it might be helpful to see your K 1.6 configuration report.
