Important Installation of 1.5.14 in preparation for Agora conversion error
15 years 7 months ago #86018
Replied by sozzled on topic Re: Installation of 1.5.14 in preparation for Agora conversion error
Thank you for your reply. No, you should not have received that message. I will try a similar experiment myself. I will try to install K 1.5.14 on a fresh clean J! 1.5.22 site and, if I get into the same situation as you, I will report this to the development team. Theoretically, though, K 1.5.14 is identical to K 1.5.13 except for one small difference in one file.
15 years 7 months ago - 15 years 7 months ago #86019
by Wineblue2
Replied by Wineblue2 on topic Re: Installation of 1.5.14 in preparation for Agora conversion error
OK well this is a fresh (3 weeks old) install of J 1.5.22 with only Akeeba Admin tools and Akeeba Backup on it with Chromoforms. Also, I just uninstalled it using the uninstaller and I got the following error despite it showing the component was uninstalled:
XML Parsing Error at 3:84. Error 9: Invalid character
Last edit: 15 years 7 months ago by Wineblue2. Reason: additional info
15 years 7 months ago #86021
I'll let you know what I find on a totally brand-new, untarnished, no modifications made to it, stock standard, vanilla-flavoured J! 1.5.22 site.
15 years 7 months ago #86029
I agree with you. I also cannot install K 1.5.14 on a clean J! 1.5.22 website (.ZIP format, .TAR format or .TAR.GX format).
I had no difficulties installing K 1.5.13, however. For the the temporary purposes that you need K 1.5, I would suggest that you install K 1.5.13 and then upgrade to K 1.6.3 after you have migrated your Agora forum.
I have reported this problem to the development team.
15 years 7 months ago #86033
by Wineblue2
OK I'll try to and let you know what happens.
15 years 7 months ago #86035
by Wineblue2
OK well I looked for that particular version but it does not appear to be in the file directory where I found 1.5.14. Any chance you could give me a link to it so I can download it?
Time to create page: 0.229 seconds
