Question Top menu gone: Warning: Using direct link to Kunena component. No suitable menu item found [SOLVED]
15 years 11 months ago #72502 by karaokeamerica
paulohabl wrote: SOLVED!!!
Looking around I saw the forum About Menu and learnt from there there is an icon in Control Panel called Create Menu. I clicked on it and the magic was done. Menu is now re-appeared!!!
I never could imagine a menu needs to be created. And why the menu disappeared in first instance. So if there is an expert with time available to teach us the cause, it would be great.
Thanks to all for your support anyway.
Kind regards
Paulo Habl
I have the opposite problem. I went from 1.5x to 1.6x and it created an extra menu in my hornav position in the japurity template and I can't get rid of the menu. I can move the functional menu that is created to a sub-menu position no problem, but I can't get rid of the extra menu created in the root of the hornav position even if I delete the module. I don't know where it came from. It can be seen here: www.karaoke-america.com .
Time to create page: 0.101 seconds
