Question Top menu gone: Warning: Using direct link to Kunena component. No suitable menu item found [SOLVED]
15 years 11 months ago - 15 years 11 months ago #72370 by paulohabl
The top menu is not available, not shown.
Opted for Debug Message in the contol panel and got the following message when navigating internally.
Warning: Using direct link to Kunena component. No suitable menu item found.
For your reference the link is www.wimbledonchase.co.uk > Lets Chat
I have an impression that when it was first isntalled it had the menu.
Could you please advise. It needs to released soon and I am a bit anxious.
Regards
Paulo Habl
Kunema Version 1.6.1
Last edit: 15 years 11 months ago by paulohabl.
15 years 11 months ago #72371 by Oscarfishlover
Have you upgraded from 1.5? Have you deleted all old links pointing to the old forum?
The #1 Oscar Fish website on the net
Joomla! 2.5.14
Kunena 3.0.2
The following user(s) said Thank You: paulohabl
15 years 11 months ago - 15 years 11 months ago #72372 by paulohabl
Fresh install 1.6.1
I might have reintalled at the begining, cant remember by now.
Also I have recently restored the database.
15 years 11 months ago #72386 by paulohabl
15 years 11 months ago #72394 by xillibit
Can-you put here please your kunena report configuration settings ?
15 years 11 months ago #72396 by paulohabl
SOLVED!!!
Looking around I saw the forum About Menu and learnt from there there is an icon in Control Panel called Create Menu. I clicked on it and the magic was done. Menu is now re-appeared!!!
I never could imagine a menu needs to be created. And why the menu disappeared in first instance. So if there is an expert with time available to teach us the cause, it would be great.
Thanks to all for your support anyway.
Kind regards
Paulo Habl
