Question (SOLVED) long lag time opening kunena. script not working
16 years 4 weeks ago #68275 by haithun
Well your whole configuration is bad for Kunena 1.6.
First of all you should disable legacy mode, as second you should enable the SEF and also the MooTools Upgrade plugin. Please update your Kunena Latest Modul as fourth.
This will make your site working much better.
16 years 4 weeks ago #68276 by ae3d
haithun wrote: Please update your Kunena Latest Modul as fourth.
i made the changes you replied with above
and tested it out a bit but you mentioned my Kunena Latest Module?
i know what its for because i have it on another website
but i don have it on this one.
Id like to but i cant find the module download for K 1.6
Im pretty sure the one for K 1.5 is not going to work for me here
16 years 4 weeks ago #68301 by sozzled
ae3d wrote:
K1.6 is greatly different from its previous version
This is the most important message we have been trying to get across to those people who are used to Fireboard and/or Kunena 1.5. Kunena 1.6 is completely differently designed to what people have been familiar with before. I spent about 6 months trying to gradually introduce people to the many differences in Kunena 1.6 - a moderator's view .
K 1.6 represents a generational difference from K 1.5! You should read Kunena:About in the Wiki. ;)
K 1.6 represents a great opportunity for people to make a difference to their websites, to look again at what they've been doing and to eliminate performance bottlenecks that they have introduced into their websites. It also offers the opportunity for people to eliminate obsolete extensions that they installed ages ago and that they've probably forgotten about. One of these issues concerns the continued usage of Legacy mode. Please read the important information about Legacy mode in the Wiki.
Just as importantly as it is to get rid of old software that will hold you back from keeping your website running cleanly, running smoothly - and that, after all, is really what this discussion topic is all about - is the need to eliminate all that old rubbish, the unsupported software that people obtained years ago and that they've never done anything with. One of those things was the old "latest posts" module that was put together for Kunena 1.5. This "latest posts" module has a very long and very unflattering history as you will see by looking at this discussion topic . When you read the K 1.6.0 release notes , you will see an important piece of advice (I've reproduced it below):
As far as the new K 1.6 "latest posts" module is concerned, you only have to ask where to obtain the software: joomlacode.org/gf/project/kunena/frs/?ac...&frs_package_id=5370
