Question (SOLVED) long lag time opening kunena. script not working
16 years 4 weeks ago - 16 years 4 weeks ago #68216 by ae3d
each time i goto my forum it takes a LOOONG time to load the page
then a box pops up telling me a script timed out
its only on this component in my joomla site
the site is VERY fresh. It has no other information and im still setting it up
my kunena version is
Installed version: Kunena 1.6.0
joomla Version 1.5.21
PHP is 5.2.14
goto this link and youll see what i mean
infact it froze my browser for a few seconds and then let it loose
tranceunitesus.com/site/index.php?option...w=listcat&Itemid=189
Also i keep trying to create a menu item to my forum
i tried using the INDEX
but it tells me NO CATEGORY SELECTED
i want FORUM or MESSAGE BOARDS to bring me to the main area of the forums
where it shows me all the CATEGORIES
What am i missing and why this LAG time?
Last edit: 16 years 4 weeks ago by ae3d.
16 years 4 weeks ago #68254 by haithun
Two ideas:
First one is that you do not have enough memory. (Please post a Config Report)
Second one is that there is a problem with the CSS3.
16 years 4 weeks ago #68257 by ae3d
and how do i produce a CONFIG report?
16 years 4 weeks ago #68261 by xillibit
ae3d wrote: and how do i produce a CONFIG report?
Look here : www.kunena.com/forum/168-k-16-support/56...-when-asking-support
16 years 4 weeks ago #68266 by ae3d
now thats a nifty little trick there hommie. Im sorry i didnt quite understand what it was for earlier.
K1.6 is greatly different from its previous version
here is the report you asked for
Legacy mode: Enabled | Joomla! SEF: Disabled | Joomla! SEF rewrite: Disabled | FTP layer: Enabled |
htaccess: Missing | PHP environment: Max execution time: 120 seconds | Max execution memory: 99M | Max file upload: 2M
Modules: Kunena Latest: Enabled (Version : 1.0.47) | Kunena Stats: Disabled or not installed | Kunena Login: Disabled or not installed
16 years 4 weeks ago #68273 by ae3d
i MAY have found the issue
apparently its a MOOTOOLS / Javascript conflict between K1.6 and the template im using.
In this particular templates settings
there is an area wich askes me YES OR NOT to
Enable MooTools = Enable / diable mootools 1.11 Javscript library
Must be some conflict with the mootools versions
What do you think? Because i have some Javascript activated in the main menu
and i can get to the forums easily with no strange lagging
