Question problem fo uploading images and files
16 years 1 month ago - 16 years 1 month ago #66588 by blondu_mm
I uninstalled kinespere. I read about legacy mode and disabled it. (i do not have non native 1.5 joomla extensions)
but I have the same problem. now my report looks like this:
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Disabled or not installed | Jomsocial: Disabled or not installed | UddeIm: Installed (Version : 1.9)
Last edit: 16 years 1 month ago by blondu_mm.
16 years 1 month ago - 16 years 1 month ago #66897 by blondu_mm
I reinstalled kunena, searched on the forum and over the internet but i wasn't able to fix this problem.
And i can not reported as a bug or something because i do not know why is this happening.
On the same server i have another kunena forum and it's work perfectly.
With the same laptop/ firefox i opened a kunena forum (ardei-iute.ro) ant it's working ok.
I believe the problem is on my configurations or something.
If you had the same problem or now what to do please give me a hint.
16 years 1 month ago #66902 by sozzled
Yes, we can provide you with a hint. You have a conflicting Javascript function call - this has been mentioned before on at least two earlier occasions in this discussion.
The conflicting Javascipt library could originate from one of the following places (but this is not an exhaustive list):
A plugin
A module
A template
As you know, you have another site with Kunena installed that's working fine. What's the difference between these two site?
Let's narrow down the field of usual suspects:
(1) How many plugins do you have installed? When did you last check for updates for any of them? Do you need them all?
(2) How many modules do you have installed? When did you last check for updates for any of them? Do you need them all?
(3) How many templates do you have installed? When did you last check for updates for any of them? Surely you only need to keep no more than 3 (rhuk_milkyway, JA_Purity and maybe the one you're using now)?
I haven't had the same problems as you have had.
16 years 1 month ago #66906 by blondu_mm
one question:
if the plug-in /module is disable can it have a conflict with interact with the java script library?
16 years 1 month ago #66926 by haithun
No if it is disabled there is nothing loaded and therefore there could be no conflict.
Check your template too cause many old templates had a line to disable Mootools.
16 years 6 days ago - 16 years 6 days ago #71354 by blondu_mm
Hi all,
I checked all the extensions that are enable on my site, I checked the template, but I can not find what generate my problem and how to fix it.
I also installed the new kunena version.
I deleted and uninstall all the module, plugins, components that i don't need
attached you can see two pages from desmoriders.ro and adopt24.ro
kunena is working on adopt24.ro, i marked with red the diferences from the kunena forum file.
www.desmoriders.ro/upload/adopt24.ro.JPG
www.desmoriders.ro/upload/desmoriders.ro.JPG
Last edit: 16 years 6 days ago by blondu_mm.
Time to create page: 0.170 seconds
