Question problem fo uploading images and files
16 years 1 month ago #66464 by blondu_mm
hi,
i have a problem with the uploaded for kunena 1.6 stable edition.
when I'm trying to upload an image, i select the image, and nothing happens.
but, if i press submitt button the image is uploaded.
here is the report :
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Disabled or not installed | Jomsocial: Disabled or not installed | UddeIm: Installed (Version : 1.9)
16 years 1 month ago #66471 by haithun
Did you tried just your Firefox or also other brothers? A friend just crashed his Firefox that if he was using a proxy the HTML document was downloadable but not more. Maybe you have also a problem with your FF config.
16 years 1 month ago - 16 years 1 month ago #66473 by blondu_mm
i tried to upload images with my firefox and other 2 + ie.
a friend of mine has the same version of kunena and from my laptop it works perfectly.
so, is not my computer or my browser the problem.
BUT I saw something interesting, when i uploaded the picture on this topic, in front of browsing button there is a number "1"
I can not see this number on my forum ....
Last edit: 16 years 1 month ago by blondu_mm.
16 years 1 month ago #66513 by xillibit
The Mootools javascript library is not enabled on your site or it's conflicting with an other thing. Start by enabling the plugins system mootools upgrade.
16 years 1 month ago #66563 by blondu_mm
i enabled mootools plugin without solving my problem.
i installed also mootools from kinespere, but nothing.
16 years 1 month ago #66576 by sozzled
blondu_mm wrote: i enabled mootools plugin without solving my problem.
What's this "Kinespere" version Mootools? Kunena uses Joomla's Mootools 1.2.4 Javascript library that comes with J! 1.5.19+. We do not recommend other Mootools Javascript libraries and I suggest that you uninstall the "Kinespere" version/variant.
I also see from your configuration report that you have the legacy mode plugin enabled. Please see important information about Legacy mode and do something about it.
