Question Total users doesn't match up
15 years 10 months ago #82778 by Yammer
I should add that, when I installed the update, I had a quick look through the code, where I usually hack the SQL statements. I noticed that some statements had not been changed from OR to AND. However, as I have never studied the code in depth, I would not know if this was incorrect.
funcs/userlist.php line 69
lib/kunena.stats.class.php line 143
(template/default/plugin/stats/stats.class.php doesn't seem to exist any more)
15 years 10 months ago #82782 by whippet
Turk1sh wrote: has anyone figured this out. i`m having the same issue. I have over 9000 members and kunena showing 7000 and all my members are active...
Thanks in advence...
Hi! I've the same identic problem; kunena in front end doesn't show all active (enabled) users, but a "random" one (sorry for my bad english, I'm italian ;) )
I've noticed this here as sozzled tell you.
Yammer wrote: Yes. Read the first posts again.
Just noticed there's a new update. So I don't know if this has been fixed now.
What's this update? a fixed, a plugin new version of statistics that solve this problem? where we can find it ? (old kunena version simply show all active/enabled users, not all users :) and that's the right way for me!)
Yammer wrote: I've just had a closer look at all the counts. I'm struggling because I'm not sure where I should be looking. Please let me know if I've missed anywhere.
On my website, there is a total of 54 user accounts. All are confirmed and approved. 12 are disabled. 42 are active. Nice and simple.
Kunena 1.6.2 says there are 42 in the frontend forum statistics. I used to have to hack this, but now it's spot-on.
In the backend (after syncronising users with "create new accounts" ticked), User Manager shows 54 users but clearly shows 12 of them as disabled. This is as I'd expect.
now it works :) :) :) so what have you changed?
Please explain us as more simple as you can (I'm totally newbie...)
many thanks
ps perhaps finally one solution :)
15 years 10 months ago #82786 by Yammer
I am referring to the latest version of Kunena (1.6.2) which seems to have addressed the issue at the start of this topic, that it, the "total users" count at the bottom of the frontend forum page not matching the total of enabled active users.
15 years 10 months ago #82803 by whippet
Sorry, but I've migrated the latest version 1.6.2 this one (from old 1.5.12) in local site (and a friend of mine in live on-line site) and NOW (we) I've a problem with the "total users" count at the bottom of the frontend forum page that not matching the total of enabled active users...
I do not understand, feel sorry for my English, but do you say that the problem for you is solved?
How can I solved it?
many thanks again :blush:
