Question Having problems uploading photos
16 years 1 month ago #64426 by RCRA
No its not completly resolved. I get this error when I try to upload a photo. It will upload them but it loses all template formating and you have to go back and edit the post to insert the photo
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.0; WOW64; Trident/4.0; GTB6.6; SLCC1; .NET CLR 2.0.50727; Media Center PC 5.0; .NET CLR 3.5.21022; .NET CLR 3.5.30729; .NET CLR 3.0.30729; .NET4.0C)
Timestamp: Thu, 7 Oct 2010 20:34:22 UTC
Message: Number expected
Line: 1
Char: 2585
Code: 0
URI: www.rcracingassociation.com/plugins/syst...tupgrade/mootools.js
16 years 1 month ago #64429 by fxstein
This is a javascript error and should be independent of the underlying problem - or might be a side effect.
What we need to see is the apache error log of your server. There will be warnings and errors in it.
I suggest you do an upload that fails, then go immediately to the error log and grab any warnings or errors at the very end of the file and post them here. The should tell us right away what is wrong with your system.
16 years 1 month ago - 16 years 1 month ago #64432 by RCRA
I Have no clue what this means.
[07-Oct-2010 11:55:52] PHP Warning: PHP Startup: Unable to load dynamic library '/usr/local/lib/php/extensions/no-debug-non-zts-20060613/sqlite.so' - /usr/local/lib/php/extensions/no-debug-non-zts-20060613/sqlite.so: cannot open shared object file: No such file or directory in Unknown on line 0
[07-Oct-2010 11:55:52] PHP Warning: PHP Startup: Unable to load dynamic library '/usr/local/lib/php/extensions/no-debug-non-zts-20060613/pdo_mysql.so' - /usr/local/lib/php/extensions/no-debug-non-zts-20060613/pdo_mysql.so: cannot open shared object file: No such file or directory in Unknown on line 0
[07-Oct-2010 12:04:16] PHP Warning: PHP Startup: Unable to load dynamic library '/usr/local/lib/php/extensions/no-debug-non-zts-20060613/pdo.so' - /usr/local/lib/php/extensions/no-debug-non-zts-20060613/pdo.so: cannot open shared object file: No such file or directory in Unknown on line 0
[07-Oct-2010 12:04:16] PHP Warning: PHP Startup: Unable to load dynamic library '/usr/local/lib/php/extensions/no-debug-non-zts-20060613/pdo_sqlite.so' - /usr/local/lib/php/extensions/no-debug-non-zts-20060613/pdo_sqlite.so: cannot open shared object file: No such file or directory in Unknown on line 0
[07-Oct-2010 12:04:16] PHP Warning: PHP Startup: Unable to load dynamic library '/usr/local/lib/php/extensions/no-debug-non-zts-20060613/sqlite.so' - /usr/local/lib/php/extensions/no-debug-non-zts-20060613/sqlite.so: cannot open shared object file: No such file or directory in Unknown on line 0
[07-Oct-2010 12:04:16] PHP Warning: PHP Startup: Unable to load dynamic library '/usr/local/lib/php/extensions/no-debug-non-zts-20060613/pdo_mysql.so' - /usr/local/lib/php/extensions/no-debug-non-zts-20060613/pdo_mysql.so: cannot open shared object file: No such file or directory in Unknown on line 0
[07-Oct-2010 12:04:19] PHP Warning: PHP Startup: Unable to load dynamic library '/usr/local/lib/php/extensions/no-debug-non-zts-20060613/pdo.so' - /usr/local/lib/php/extensions/no-debug-non-zts-20060613/pdo.so: cannot open shared object file: No such file or directory in Unknown on line 0
[07-Oct-2010 12:04:19] PHP Warning: PHP Startup: Unable to load dynamic library '/usr/local/lib/php/extensions/no-debug-non-zts-20060613/pdo_sqlite.so' - /usr/local/lib/php/extensions/no-debug-non-zts-20060613/pdo_sqlite.so: cannot open shared object file: No such file or directory in Unknown on line 0
[07-Oct-2010 12:04:19] PHP Warning: PHP Startup: Unable to load dynamic library '/usr/local/lib/php/extensions/no-debug-non-zts-20060613/sqlite.so' - /usr/local/lib/php/extensions/no-debug-non-zts-20060613/sqlite.so: cannot open shared object file: No such file or directory in Unknown on line 0
[07-Oct-2010 12:04:19] PHP Warning: PHP Startup: Unable to load dynamic library '/usr/local/lib/php/extensions/no-debug-non-zts-20060613/pdo_mysql.so' - /usr/local/lib/php/extensions/no-debug-non-zts-20060613/pdo_mysql.so: cannot open shared object file: No such file or directory in Unknown on line 0
[07-Oct-2010 12:04:27] PHP Warning: PHP Startup: Unable to load dynamic library '/usr/local/lib/php/extensions/no-debug-non-zts-20060613/pdo.so' - /usr/local/lib/php/extensions/no-debug-non-zts-20060613/pdo.so: cannot open shared object file: No such file or directory in Unknown on line 0
[07-Oct-2010 12:04:27] PHP Warning: PHP Startup: Unable to load dynamic library '/usr/local/lib/php/extensions/no-debug-non-zts-20060613/pdo_sqlite.so' - /usr/local/lib/php/extensions/no-debug-non-zts-20060613/pdo_sqlite.so: cannot open shared object file: No such file or directory in Unknown on line 0
[07-Oct-2010 12:04:27] PHP Warning: PHP Startup: Unable to load dynamic library '/usr/local/lib/php/extensions/no-debug-non-zts-20060613/sqlite.so' - /usr/local/lib/php/extensions/no-debug-non-zts-20060613/sqlite.so: cannot open shared object file: No such file or directory in Unknown on line 0
[07-Oct-2010 12:04:27] PHP Warning: PHP Startup: Unable to load dynamic library '/usr/local/lib/php/extensions/no-debug-non-zts-20060613/pdo_mysql.so' - /usr/local/lib/php/extensions/no-debug-non-zts-20060613/pdo_mysql.so: cannot open shared object file: No such file or directory in Unknown on line 0
[07-Oct-2010 12:05:53] PHP Warning: PHP Startup: Unable to load dynamic library '/usr/local/lib/php/extensions/no-debug-non-zts-20060613/pdo.so' - /usr/local/lib/php/extensions/no-debug-non-zts-20060613/pdo.so: cannot open shared object file: No such file or directory in Unknown on line 0
[07-Oct-2010 12:05:53] PHP Warning: PHP Startup: Unable to load dynamic library '/usr/local/lib/php/extensions/no-debug-non-zts-20060613/pdo_sqlite.so' - /usr/local/lib/php/extensions/no-debug-non-zts-20060613/pdo_sqlite.so: cannot open shared object file: No such file or directory in Unknown on line 0
[07-Oct-2010 12:05:53] PHP Warning: PHP Startup: Unable to load dynamic library '/usr/local/lib/php/extensions/no-debug-non-zts-20060613/sqlite.so' - /usr/local/lib/php/extensions/no-debug-non-zts-20060613/sqlite.so: cannot open shared object file: No such file or directory in Unknown on line 0
[07-Oct-2010 12:05:53] PHP Warning: PHP Startup: Unable to load dynamic library '/usr/local/lib/php/extensions/no-debug-non-zts-20060613/pdo_mysql.so' - /usr/local/lib/php/extensions/no-debug-non-zts-20060613/pdo_mysql.so: cannot open shared object file: No such file or directory in Unknown on line 0
[07-Oct-2010 12:06:14] PHP Warning: PHP Startup: Unable to load dynamic library '/usr/local/lib/php/extensions/no-debug-non-zts-20060613/pdo.so' - /usr/local/lib/php/extensions/no-debug-non-zts-20060613/pdo.so: cannot open shared object file: No such file or directory in Unknown on line 0
[07-Oct-2010 12:06:14] PHP Warning: PHP Startup: Unable to load dynamic library '/usr/local/lib/php/extensions/no-debug-non-zts-20060613/pdo_sqlite.so' - /usr/local/lib/php/extensions/no-debug-non-zts-20060613/pdo_sqlite.so: cannot open shared object file: No such file or directory in Unknown on line 0
[07-Oct-2010 12:06:14] PHP Warning: PHP Startup: Unable to load dynamic library '/usr/local/lib/php/extensions/no-debug-non-zts-20060613/sqlite.so' - /usr/local/lib/php/extensions/no-debug-non-zts-20060613/sqlite.so: cannot open shared object file: No such file or directory in Unknown on line 0
[07-Oct-2010 12:06:14] PHP Warning: PHP Startup: Unable to load dynamic library '/usr/local/lib/php/extensions/no-debug-non-zts-20060613/pdo_mysql.so' - /usr/local/lib/php/extensions/no-debug-non-zts-20060613/pdo_mysql.so: cannot open shared object file: No such file or directory in Unknown on line 0
[07-Oct-2010 12:06:20] PHP Warning: PHP Startup: Unable to load dynamic library '/usr/local/lib/php/extensions/no-debug-non-zts-20060613/pdo.so' - /usr/local/lib/php/extensions/no-debug-non-zts-20060613/pdo.so: cannot open shared object file: No such file or directory in Unknown on line 0
[07-Oct-2010 12:06:20] PHP Warning: PHP Startup: Unable to load dynamic library '/usr/local/lib/php/extensions/no-debug-non-zts-20060613/pdo_sqlite.so' - /usr/local/lib/php/extensions/no-debug-non-zts-20060613/pdo_sqlite.so: cannot open shared object file: No such file or directory in Unknown on line 0
[07-Oct-2010 12:06:20] PHP Warning: PHP Startup: Unable to load dynamic library '/usr/local/lib/php/extensions/no-debug-non-zts-20060613/sqlite.so' - /usr/local/lib/php/extensions/no-debug-non-zts-20060613/sqlite.so: cannot open shared object file: No such file or directory in Unknown on line 0
[07-Oct-2010 12:06:20] PHP Warning: PHP Startup: Unable to load dynamic library '/usr/local/lib/php/extensions/no-debug-non-zts-20060613/pdo_mysql.so' - /usr/local/lib/php/extensions/no-debug-non-zts-20060613/pdo_mysql.so: cannot open shared object file: No such file or directory in Unknown on line 0
[07-Oct-2010 12:06:28] PHP Warning: PHP Startup: Unable to load dynamic library '/usr/local/lib/php/extensions/no-debug-non-zts-20060613/pdo.so' - /usr/local/lib/php/extensions/no-debug-non-zts-20060613/pdo.so: cannot open shared object file: No such file or directory in Unknown on line 0
[07-Oct-2010 12:06:28] PHP Warning: PHP Startup: Unable to load dynamic library '/usr/local/lib/php/extensions/no-debug-non-zts-20060613/pdo_sqlite.so' - /usr/local/lib/php/extensions/no-debug-non-zts-20060613/pdo_sqlite.so: cannot open shared object file: No such file or directory in Unknown on line 0
[07-Oct-2010 12:06:28] PHP Warning: PHP Startup: Unable to load dynamic library '/usr/local/lib/php/extensions/no-debug-non-zts-20060613/sqlite.so' - /usr/local/lib/php/extensions/no-debug-non-zts-20060613/sqlite.so: cannot open shared object file: No such file or directory in Unknown on line 0
[07-Oct-2010 12:06:28] PHP Warning: PHP Startup: Unable to load dynamic library '/usr/local/lib/php/extensions/no-debug-non-zts-20060613/pdo_mysql.so' - /usr/local/lib/php/extensions/no-debug-non-zts-20060613/pdo_mysql.so: cannot open shared object file: No such file or directory in Unknown on line 0
Last edit: 16 years 1 month ago by RCRA.
16 years 1 month ago #64469 by fxstein
These are all unrelated and have nothing todo with Kunena but the basic server setup, but the rate at which they occur is alarming. Looks like some database libraries are missing. This is a PHP configuration issue on your server. You are getting two errors for every page view on your site.
You should get this error taken care of - best by the support of your hosting provider.
Since there are so many of them we don't see the errors with your file uploads. I would not be surprised if some of the image handling extensions are missing as well.
Once you have eliminated these, we should be able to see the errors in regards to the image handling. Without them we really cannot help you much.
16 years 1 month ago #64487 by RCRA
Thank you for all your help. I reloaded the default php.ini file and now photo upload is working.
I am still getting this error on the page though.
Timestamp: Fri, 8 Oct 2010 05:08:51 UTC
Line: 1
Char: 2585
Code: 0
15 years 9 months ago #83623 by audisport
I have exactly the same problem with Kunena 1.6.2 in IE8 only when just validating a post (not a quick reply)...
Any idea?
Thanks guys ;)
