Question Having problems uploading photos
16 years 1 month ago - 16 years 1 month ago #64100 by RCRA
It says in your setup if a photo exceeds the size limits you set it will be resized automaticly but that function does not work.
I can upload photos if they are within the limits but can not if they are bigger
Legacy mode: Enabled | Joomla! SEF: Enabled | Joomla! SEF rewrite: Enabled | FTP layer: Disabled |
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 32M | Max file upload: 30M
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Installed (Version : 1.2.3) | Jomsocial: Disabled or not installed | UddeIm: Installed (Version : 2.0rc)
Last edit: 16 years 1 month ago by RCRA.
16 years 1 month ago #64117 by fxstein
I believe there is a misunderstanding.
Images will get resized if the height or width are larger than what you have set in your config (850).
File size is an absolut limit. If you set it to 200kB - no files bigger than 200kB will be allowed for upload.
I suggest you set the upload file size to 2048kB and since your height and width is fairly small you will end up with much smaller files anyway - but the original is kept - hence the file size limit.
16 years 1 month ago #64230 by RCRA
I have tried that I set it at 3000,4000 ,5000 exct with the same results. It is not the size of the file that is the problem it is the height and width as I stated.
16 years 1 month ago - 16 years 1 month ago #64232 by RCRA
I can now upload photos but it still does not work right. After I upload a photo my website loses all template formating and it takes you to an unformated page instead of back to the post.
Also Now I get this error when I load the forum:
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.0; WOW64; Trident/4.0; GTB6.6; SLCC1; .NET CLR 2.0.50727; Media Center PC 5.0; .NET CLR 3.5.21022; .NET CLR 3.5.30729; .NET CLR 3.0.30729; .NET4.0C)
Timestamp: Wed, 6 Oct 2010 20:34:19 UTC
Message: 'partscollect.0.style' is null or not an object
Line: 224
Char: 1
Code: 0
URI: www.rcracingassociation.com/forum.html
Here is the new settings
16 years 1 month ago #64408 by severdia
I don't see this error on your forum and it appears that images are being properly uploaded and resized:
www.rcracingassociation.com/forum/320-te...testing-uploads.html
Is your issue resolved?
16 years 1 month ago #64409 by fxstein
The place to start looking for issues is the web-server error log of your host. When you get a partial page after an upload it means something failed.
My guess is that your server might not have the imaging support installed that we need to resize images and the php function might fail due to that.
The only way to tell is through the error log.
Time to create page: 0.161 seconds
