Idea Database problem with mysql instead of mysqli
This error has nothing todo with Kunena 1.6 and is not generated by it. This is coming from anything old that you have installed (plugin or module) that is trying to access old FireBoard tables on your system. Kunena 1.6 does not use any of these.
Not sure why mysqli or mysql would make any difference here. You need to look for old Kunena or FireBoard plugins and modules and remove them.
Hope this helps!
Are there any other known incompatibilities with other components or plugins?
I will meanwhile look for old modules and plugins. Will report back if I find something.
Thanks,
Jens
In K1.6, the tables are not anymore nammed jos_fb_xxx but jos_kunena_xxx.
Since I only installed K1.6, I only have tables like jos_kunena_xxx.
I also checked all components, modules and plugins. No evidence that there was ever an older Kunena or FireBoard installation. Just to be safe I even checked all physical directories for leftover files.
Is there anything else I can check? I don't have any debugging skills, but I would gladly do some more research to identify the problem if someone can point me in the right direction. I guess it would help to know how the check is done.
This page isn't really running too many components either. Could it be a JoomSEF problem? I am using the Kunena plugin for that one.
Thanks,
Jens
jstraten wrote: Hi xillibit,
That is more than likely the problem as i doubt that plugin is for k1.6 have you got a copy of it i can look at and see if that really is the issue??
