Question K 1.6 RC1: Submit button does not work for public posts
- Gamer Templates
- Senior Member
16 years 3 months ago - 16 years 3 months ago #58478
by Gamer Templates
Hello Team, the SUBMIT button don´t send new postings! (Red erros works fine)
Look here: My Forum
I deactivated for testing my SEF.
I testing with and without captcha. No solution.
I think there is a Javascript problem but i can´t find it!
Any idea?
Smilies and BBC don´t work too...
Thanks for help!
Look here: My Forum
Any idea?
Thanks for help!
Last edit: 16 years 3 months ago by sozzled. Reason: Changed subject to improve search relevance
The topic has been locked.
16 years 3 months ago - 16 years 3 months ago #58481
Replied by sozzled on topic Re: SUBMIT Button don´t work!
The Submit button is deactivated in the following circumstances:
(1) If you attempt to post a message without a subject
(2) If you attempt to post a message without any contents in the message
[strike](3) If you have not enabled the Joomla Mootools 1.2 system plugin
[/strike](4) If you have not enabled the Joomla Mootools Upgrade system plugin
(5) If you have enabled another Javascript library that overrides the functions in the Joomla Javascript libraries, required by Kunena, in [strike](3) and[/strike] (4) above
- Gamer Templates
- Senior Member
16 years 3 months ago - 16 years 3 months ago #58482
by Gamer Templates
Replied by Gamer Templates on topic Re: SUBMIT Button don´t work!
I check all points. Don´t work!
Kunena 1.5 works fine without any problems on my site. Are there any changes in 1.6?
And see my first posting: RED ERROS WORKS (1) & (2) -> ONLY SENDING DONT WORK!
Thanks!
Thanks!
Last edit: 16 years 3 months ago by Gamer Templates.
16 years 3 months ago #58606
by Matias
Replied by Matias on topic Re: SUBMIT Button don´t work!
What does happen when you send the post? Does it go into wrong page? And which page is that?
- Gamer Templates
- Senior Member
16 years 3 months ago - 16 years 3 months ago #58611
by Gamer Templates
New informations!
The SUBMIT button works only with registration. Not with Public Read/Write! I think there is no Javascript problem.
Is this a public read/write bug?
I change joomla template, captcha, Mootools etc.
Hello Matias, check this here (for example): Thread
Do this STEP BY STEP!
Press SUBMIT -> Red Errors -> write email, subject, message, captcha -> Press SUBMIT -> Nothing
When you registered this link works fine!
EDIT: And why is there no field for NAME? Is this the problem? Or use 1.6 only Anonymus?
Remember that kunena 1.5 works without errors! No Javascript problems!
- Gamer Templates
- Senior Member
16 years 3 months ago - 16 years 3 months ago #58612
by Gamer Templates
@ Matias
I install NEW Joomla! 1.5.20 with NEW Kunena 1.6!
Dont work too!
Look here: www.docman-demo.templates4all.de/forum/2-welcome-mat.html
I think there is a public read/write bug!
Greetings from germany!
Edit: UPS! Sorry for second posting! Next time i use the edit button!
Dont work too!
Time to create page: 0.161 seconds
