Bug [Problem assumed resolved - no response from user] Double popop of images
14 years 6 months ago - 14 years 4 months ago #119672 by djb
I am using Kunena 1.7.2 on J1.5.22 and Multithumb 2.4.4.0.
My Kunena forum works well and I am very happy with it.
The only issue I have is that embedded images in posts open up two popup windows when clicked. Here is an example: www.angloboerwar.com/forum/16-on-this-day/2410-march-1st
In Multithumb, there is a command {nomultithumb} which can be inserted into articles to stop multithumb. This works for articles but, if this is the answer, I am not sure where to lodge this code. I tried it in kunena.php but that just stopped the forum from loading :(
Any help would be much appreciated.
With thanks
David
Here is the config report from my local copy of live:
Legacy mode: Disabled | Joomla! SEF: Disabled | Joomla! SEF rewrite: Enabled | FTP layer: Disabled |
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 128M
Joomla default template details : rhuk_milkyway | author: Andy Miller | version: 1.0.2 | creationdate: 11/20/06
Third-party components: UddeIm 2.6
Modules: Kunena Latest 1.7.1
Last edit: 14 years 4 months ago by sozzled. Reason: Change subject and topic icon
14 years 6 months ago #119673 by Jiminimonka
Hi djb, welcome to Kunena,
Please read the guidelines at the top of this page, and post your configuration report (un-edited).
Thanks.
Please read the FAQ.
Only one question per topic.
14 years 6 months ago - 14 years 6 months ago #119679 by xillibit
Replied by xillibit on topic Re: Double popop of images
You need to made a clean up in your Kunena menu because you have multiples sames items. You need to remember that each menu item need to have his own alias.
I advise you to upgrade as soon as possible to Joomla! 1.5.25.
Kunena has his own thing to display image in pop-up, you can maybe disable your other plugin for pop-up image.
Last edit: 14 years 6 months ago by xillibit.
14 years 6 months ago #119681 by djb
Replied by djb on topic Re: Double popop of images
Jiminimonka,
I have regenerated the report and pasted it into the email. It has not been edited in any way.
Regards
David
14 years 6 months ago #119683 by djb
xillibit
Thank you. I will investigate your suggestions.
With thanks
David
14 years 6 months ago #119708 by sozzled
Replied by sozzled on topic Re: Double popop of images
djb wrote: I have regenerated the report and pasted it into the email. It has not been edited in any way.
Thanks, David, and welcome to Kunena, by the way :)
I don't know what Multithumb is, what it does or whether (or how) it affects Kunena. My search on Google informed me there are several Joomla extensions called "Multithumb". Do you have a citation for the particular extension that you're using, perhaps on the Joomla Extension Directory ?
I do, however, know something about problems that people have, asking for our help, on a site that the rest of the world cannot access. Please read what I wrote earlier today in "fatal error" when everything seemed ok! . My comments there apply equally here, too.
