Question SOLVED:: Unable to move posts/replies to other topics + more rel. issues
14 years 10 months ago - 14 years 9 months ago #115796 by danss2
htaccess: Exists | PHP environment: Max execution time: 300 seconds | Max execution memory: 128M | Max file upload: 10M
Joomla default template details : sekretwhitegrayclean11 | author: Dan A | version: 1.1 | creationdate: 2011-12-30
Kunena default template details : Blue Eagle (default) | author: Kunena Team | version: 1.7.1 | creationdate: 2011-11-16
Third-party components: AlphaUserPoints 1.5.13 | Jomsocial 2.4.0
Plugins: System - Mootools Upgrade: Enabled | System - Mootools12: Disabled | My Kunena Forum Posts 1.6.0-RC1
Modules: Kunena Latest 1.6.2 | Kunena Stats 1.6.2
Hi all :)
My forum worked very well last almost 2 years, through all the upgrades and stuff, and I just noticed couple of days ago, that some of my replies post into wrong topics. As soon as someone clicks on "Reply" to open editor, right away can notice, that the system put's him into a different topic, then the person was reading and presses "Reply" from.... Also, when I try to moderate the post, to move it into correct topic, it loads completely different reply to move....
I have done quite a bit to the content on the site in the last month, such as installing K2 and redoing all the content to work with K2 and stuff, but did not do anything to the forum....
Any one ran into this kind of issue before and figured out the way out? I can't seam to find anything even remotely related to this issue throughout the forums anywhere...
Last edit: 14 years 9 months ago by danss2.
14 years 10 months ago #115797 by sozzled
You have issues with your Joomla menu. You have two menu items with the same alias. I suggest that you first simplify your Joomla menu. See How do I restore my Kunena menu?
You are using old versions of Kunena Latest and Kunena Stats. Please upgrade to the version compatible with K 1.7.1
I hope this helps.
14 years 10 months ago #115799 by danss2
That was fast... :-)
Thank you, Sozzled, I'll try your suggestions and report back
14 years 10 months ago #115802 by danss2
Ok, did that and it did not change anything... :-(
One more thing i forgot to mention: one of the topics disappeared and now shows the name of that topic as a sub-topic in every topic (at least ones I tried)...
14 years 10 months ago #115805 by sozzled
Very peculiar. Joomla menus are not the easiest things to work with. Problems, as you have described them, are related to Joomla menus and Joomla SEO.
There is no harm in using customised Joomla menus, as long as you observe certain rules. These rules are described in Customised menus . If you have followed those rules then you should have no problems. I prefer to start with a known baseline, that is, a simple Joomla menu. You have a more complicated menu than what exists on most sites.
14 years 10 months ago - 14 years 10 months ago #115809 by danss2
Hmm,... but I'm not using Kunena menu module at all... Haven't been for a long time....
Or does it matter?
Edit - in the course of the changes i made past month or so, i did change couple of buttons in the main Joomla menu...Bu they had nothing to do with Kunena, though....
Last edit: 14 years 10 months ago by danss2.
Time to create page: 0.158 seconds
