Bug [Problem assumed resolved - no response from user] Kunena Offline?
15 years 2 months ago #107806 by amarks
Replied by amarks on topic Re: Kunena Offline?
It was already at 1.7 and online. This happened once earlier too... it just goes offline. That is why the "install 1.7" is not available, because it already is 1.7.
Is there a file in ftp can can put the forum online? Because I can't access through configuration on backend.
Thanks Matias
15 years 2 months ago #107810 by Matias
Replied by Matias on topic Re: Kunena Offline?
You get this message also if tables (jos_kunena_version) in the database become unavailable (broken or destroyed). If this happens, Kunena just cannot work, because it believes that it hasn't been installed. In this case Kunena is also put offline.
Another reason may be that you have used automatic update function from Joomla 1.7. It has a bug as it doesn't run post-installation script, which means that our installer doesn't run. In that case you need to do it manually just after upgrading Kunena.
You should be able to install Kunena 1.7 as many times as you want to -- there's nothing that prevents it as installer automatically detects which version you have installed. But the option should be upgrade, not install...
15 years 2 months ago #107815 by amarks
How do I do it manually? Would you be able to help me do this if I give you my ftp? I would greatly appreciate it.
15 years 2 months ago #107997 by amarks
Would you be able to help me with this?
15 years 2 months ago #108000 by amarks
I uninstalled and reinstalled again, and the same screen popped up. What else can I do to fix this?
15 years 1 month ago #108518 by Matias
Sorry, I've been away.
Can you provide screenshot from the screen as I'm not even quite sure what's the issue. There are multiple possibilities.
