Bug [Problem assumed resolved - no response from user] Kunena Offline?
15 years 2 months ago - 15 years 2 months ago #107704 by amarks
Kunena Offline? was created by amarks
I have Kunena installed, but for some reason it went offline by itself. It won't let me go into configuration to put it online. Is there a way to do this from ftp?
I tried installing 1.7 extension again and same message. I have custom things done on kunena and can't lose it :-/
Please help guys?
Thanks!
Last edit: 15 years 2 months ago by amarks.
15 years 2 months ago #107713 by Matias
Replied by Matias on topic Re: Kunena Offline?
Kunena goes offline until it has been fully installed. In this point it hasn't yet copied the files or updated database.
Looks like this is new installation. :)
Don't let text in the green box confuse you -- it's a mistake in language file. So just click it.
The following user(s) said Thank You: amarks
15 years 2 months ago #107780 by amarks
Replied by amarks on topic Re: Kunena Offline?
I clicked that on a copy of my site and it reset everything and made kunena look different... I can't have that happen.
15 years 2 months ago #107789 by Matias
Of course it does that. Files included in Kunena package are not meant to be edited. If you want to modify template, you should copy it into another folder and rename it. In that way you will keep your changes.
As our documentation says: you need to be prepared that all files in Kunena distribution gets overwritten on every update. That's true with all software -- if we wouldn't do that, you would probably have broken site after customizations.
15 years 2 months ago #107792 by amarks
I don't mean just customizations, but all of the forums, categories, posts, etc. They all disappear
15 years 2 months ago #107797 by Matias
I thought that you have new forum, not existing one. OK, that explains it..
Kunena itself doesn't remove any data unless you uninstall it from Kunena installer. That option will destroy everything you had as it's meant to be used only if you really want to get rid of Kunena.
So what have you done? Are you trying to migrate from Joomla 1.5 to 1.7 with JUpgrade? If you are, there is a bug in JUpgrade 1.2.1 which prevents Kunena from importing.
