- Thank you received: 565
Bug [Problem assumed resolved - no response from user] Slimbox problem
Try default template -- does it work?
Can I replace the slimbox.js with a newer version to see if it works? Where can I find that file?
I meant if you have the same issue with images in default template..?
It would help a lot if we understood what you mean by "the default template doesn't really work well". I suggest that you look at the posting guidelines printed at the top of this page. Most of our responses are based on the general understanding of how Kunena is supposed to work; sometimes people do things differently and it would help to know more about your unique situation.Oscar2 wrote: Hm, the default template doesn't really work well it seems.
Is it the slimbox.js file? Or mootools? Perhaps I can replace the entire slimbox.js file, can I download it somewhere?
You may login with:
