Bug [Problem assumed resolved - no response from user] Slimbox problem
15 years 5 days ago #111561 by Oscar2
Replied by Oscar2 on topic Re: Slimbox problem
I changed the .js files for the slimbox-min and default-min. Still cant open the images!
15 years 5 days ago #111573 by xillibit
Replied by xillibit on topic Re: Slimbox problem
What Kunena template are-you using ?
15 years 5 days ago #111579 by Oscar2
The 'example' template (default), with tweaks in colors etc.
See www.bonsaiempire.nl/forum
15 years 4 days ago #111596 by Matias
Replied by Matias on topic Re: Slimbox problem
Guests are not allowed to see the attachments.
You have enabled some kind of JS/CSS minifier. They usually cause a lot of troubles with many components (no idea why), so please try to disable the plugin and try if the attachments work without.
15 years 4 days ago - 15 years 3 days ago #111613 by sozzled
Replied by sozzled on topic Re: Slimbox problem
xillibit wrote: What Kunena template are-you using ?
Oscar2 wrote: The 'example' template (default), with tweaks in colors etc.
Try using the Blue Eagle template instead. The Example template is not a fully-operational template; it's a "template" for developers of Kunena templates to extend and create new templates from.
Matias is also right: CSS/Javascript aggregators cause lots of problems. Try turning off the one you're using.
Last edit: 15 years 3 days ago by sozzled.
The following user(s) said Thank You: Oscar2
15 years 4 days ago #111657 by Oscar2
Hi Matias and sozzled, thanks for your help!
I enabled guest pictures; you can open them now. I also tried turning off the finalizer, didnt help (tested this before).
For not-loggedin visitors the pictures open in a new screen (because mootools is enabled only for logged-in visitors?!). For logged-in visitors, the pictures open in a slimbox but only half of them. See the screenshot in previous reply to this topic.
It seems as if mootools is the problem?
