Question Notifications do not work in blocked categories
15 years 4 months ago #100770 by sozzled
See what I wrote here . You should never use server caching with a website that has continually changing content.
15 years 4 months ago #100771 by pequeno74
Thanks. I did it yesterday, but don´t solve the problem.
15 years 4 months ago #101504 by pequeno74
Is there some information about? The problem persist.
15 years 4 months ago #101512 by sozzled
I don't know. See Is the "Remember me" function controlled by the session lifespan?
What are the values on your site for each of those five things listed? :unsure:
15 years 4 months ago #101514 by pequeno74
(1) If you have it enabled, disabled System - Cache plugin OK
(2) Global Configuration » Cache Settings » Cache = No OK
(3) Global Configuration » Session Settings » Session Lifetime = 30 minutes (this should be quite adequate for most environments) OK
(4) Global Configuration » Session Settings » Session Handler = Database OK
(5) Forum Configuration » General » Basic Settings » Session Lifetime = 1800 (= the same as (3) above) OK
15 years 4 months ago #101519 by sozzled
Thank you.
I'm sorry. I don't know how to help you fix this problem.
The idea of receiving notifications to updated topics that are locked is not one that I've personally had any involvement with (I've not had the need). Perhaps someone else may be able to shed some light on the issue. Maybe it can't be done? I don't know without spending time doing further testing.
There's a much easier way, anyway, instead of using locked topics. Create a separate category for those closed discussions, give your moderators additional rights so that they are the only ones who can access that category, and notifications should work. Probably better than trying to do this from a locked topic. See Sections, Categories, sub-Categories (Part 2) - advanced setup for special groups for more information on this idea.
The following user(s) said Thank You: pequeno74
