Question J! 1.5.23 with System - Cache plugin enabled: guests do not see their posted messages (registered users do)
15 years 2 months ago #102936 by sametoy
Unfortunately, I have the same problem, but the Joomla caching turned off.
I thought maybe it's because of moderation, but moderation off did not help.
I clear out the cache and new post guest shows.
site: kryla.com.ua/index.php/forum/index.html
Thank you and success in your work
Config:
15 years 2 months ago #102954 by [email protected]
Hi Sametoy,
I think maybe you are confusing the cache setting in "Global Configuration" with the plugin "System - Cache". Go to Plugin Manager and disable "System - Cache" and see if that does the trick. I have the cache in "Global Configuration enabled and the System - Cache disabled and Kunena works fine. System - Cache is a page cache that is separate and different than the cache in Global Config.
Regards
15 years 2 months ago #103046 by sametoy
Time to create page: 0.264 seconds
