- Thank you received: 1
Important Installation of 1.5.14 in preparation for Agora conversion error
Fatal error: Call to a member function getAttribute() on a non-object in /home/globalte/public_html/administrator/components/com_kunena/lib/fx.upgrade.class.php on line 255
Huh?!
Furthermore, upon installation of Kunena Converter and running it I get the following:
Notice: Undefined index: birthdate in /home/globalte/public_html/administrator/components/com_kunenaconverters/models/kunenaconverters.php on line 78
Fatal error: Uncaught exception 'Exception' with message 'KunenaConvertersModelKunenaConverters::_insertData failed. (Table 'globalte_jo151.jos_fb_users' doesn't exist SQL=INSERT INTO jos_fb_users (userid,posts,signature,gender,location,SKYPE,websiteurl) VALUES ('62','26','Regards, Robert Easterling Founder/President','1','Edgerton, WI.','globalteamdirect',' www.globalteamdirect.com '))' in /home/globalte/public_html/administrator/components/com_kunenaconverters/models/kunenaconverters.php:367 Stack trace: #0 /home/globalte/public_html/administrator/components/com_kunenaconverters/models/kunenaconverters.php(100): KunenaConvertersModelKunenaConverters->_insertData('fb_users', Array) #1 /home/globalte/public_html/administrator/components/com_kunenaconverters/models/kunenaconverters.php(34): KunenaConvertersModelKunenaConverters->_importAgoraUsers() #2 /home/globalte/public_html/administrator/components/com_kunenaconverters/controllers/kunenaconverters.php(37): KunenaConvertersModelKunenaConverters->agora() #3 /home/g in /home/globalte/public_html/administrator/components/com_kunenaconverters/models/kunenaconverters.php on line 367
Sigh! So much for this being as easy as everyone else had described! HELP!
So, let's start with getting the basics right. Look at K 1.6 Technical Requirements (you're going to need to make sure your site meets those anyway).
My advice to you: prove the concept first! Establish that your server can host K 1.6 (even though you are going to install K 1.5) and then work from that basis.
Start with a clean J! 1.5.22 site, then add K 1.5.22 and prove that you do not get those installation errors. The rest of the process is not too difficult after that.
