Posting guide:
For a quick response, please give us as much information that helps us to understand the problem.
Please read first What information should I include when I ask for help (including how to post my configuration report)?
This category is for:
  • Kunena 1.7 product-related issues only; and
  • when your Kunena forum does not work.
Do not use this category:
  • to request adding to or removing from the standard features of Kunena;
  • if your question is of a commonly asked "how to" nature;
  • if you are not using the latest stable release of Kunena; or
  • ▪ general Joomla or website adminstration matters
General hints: How To Ask Questions The Smart Way .
Please read the guides posted as sticky topics in this category.
Also refer to the FAQs menu tab above for frequently asked questions.
Note: Support for, and all questions relating to, K 1.7 will cease on 31 August 2012. Our advice is, if you are having problems with K 1.7, to upgrade to K 2.x as soon as practicable,
Merged [Merged topic] Max signature length not implemented
13 years 11 months ago #124248 by 810
thnx for the report. I just fixed it.
13 years 11 months ago - 13 years 11 months ago #124271 by michalis
the default is set to 50 characters max
but it doesnt matter if I set it to 0 or 200, it still does not limit signature length, and when the signature is too big is messes with the template it seems, where some buttons do not show
can someone tell me how to make the max. signature length work, or alternatively, how to disable signatures?
I am useing joomla 2.5.4 and kunena 1.7.2
dont know if it makes any difference, I have also installed alphauserpoints 1.7 but I am still using kunena profile
Last edit: 13 years 11 months ago by sozzled. Reason: Change topic icon
13 years 11 months ago #124317 by michalis
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 50M | Max file upload: 15M
Joomla default template details : ifreedom-fjt | author: FJT | version: 2.5.0 | creationdate: 12-04-2012
Kunena default template details : nts_krevista | author: 9ThemeStore | version: 1.7.2 | creationdate: 2011-05-07
Third-party components: AlphaUserPoints 1.7.3 | UddeIm 2.7
13 years 11 months ago #124390 by michalis
help?
13 years 11 months ago #124392 by Matias
It seems to be a bug in K1.7.2 which is fixed in K2.0 RC1. Stable is few weeks away.
13 years 11 months ago - 13 years 11 months ago #124404 by michalis
there is no fix for the current version?
k2 may only be a few weeks away but most people like me will not be implementing it for a while until components/templates become compatible
or preferably I'd like to disable it completely, I found a way to do it on the forum but it is for an older version, can you guide me through the process for the current version?
Last edit: 13 years 11 months ago by michalis.
Time to create page: 0.332 seconds
