This category is only for reporting defects or problems with Kunena 1.6 test versions with Joomla 1.6. This is NOT a support forum - there is no support for test versions. Users should NOT install K 1.6 alpha or beta test versions on websites with live production data.
Question Fresh Install Fails to Display
15 years 9 months ago #85243 by falsealarm
I uploaded the configuration settings text and as you can see from it, I am using 1.6.3. I can see the Kunena menu created after running 'Create Menu' however when I set it to default or home, or try to add a link to the Home menu for the forum as Kunena entry page, all hell breaks loose.
I do not think this has anything to do with my hosting, Apache/PHP version or any supporting software. I may however be missing a step as I could not find proper documentation for the 1.6 install.
15 years 9 months ago - 15 years 9 months ago #85246 by falsealarm
The only odd thing is that even though the Menu list shows Main and Kunena menus in the backend, this report above seems to show no Kunena menu.
When I set the Kunena menu as the default page, I can see the forum, however every single page returns a 404.
Last edit: 15 years 9 months ago by falsealarm.
15 years 9 months ago #85530 by falsealarm
Any ideas? Anyone?
15 years 9 months ago - 15 years 9 months ago #85537 by sozzled
The best idea that I can recommend to you, that will shorten the time it takes to fix your problem, is to use Joomla 1.5.22 and K 1.6.3. There are problems with K 1.6.x and J! 1.6. We know about them; we are working to fix them; it's important that we fix them ... but it takes time to do this work. If you can wait then you'll have to wait. If you can't wait then you should use J! 1.5.22
See K 1.6 Technical Requirements .
Last edit: 15 years 9 months ago by sozzled.
15 years 9 months ago #85550 by falsealarm
Alrighty, that's what I wanted to hear. I will gladly wait for the issues to be resolved before I invest any further time and effort in the 1.6 configuration. Good luck.
15 years 9 months ago #86069 by weltweites
ive got the same problem.
I just wanted to point out my details .. and ill wait for a solution .. sometime in the neqar future i hope ? ;-)
I installed also CB(latest version)
After install of kunena I got his :
Installation completed successfully.
Prepare Installation ... OK
Alter kunena_version ... OK
Uncompressing com_kunena-admin.zip ... OK
Uncompressing com_kunena-site.zip ... OK
Uncompressing com_kunena-media.zip ... OK
Installing language English (United Kingdom) ... OK
Installing System - Kunena plug-in ... OK
Installation completed successfully. ... OK
I did also a reinstall .. but sofar no luck.
Maybe just a hint ... it wasnt/isnt clear at all if Kunena runs proper on Joomla 1.6 at all or not .. i couldt find it directly on your frontpage or so .. maybe this should be considered to write as info or so ?
Other then that ... im pretty confident that you guys will "fix" Kunena so it will work with Joomla 1.6 without troubles ... thanx
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 32M | Max file upload: 20M
Joomla default template details : beez_20 | author: Angie Radtke | version: 1.6.0 | creationdate: 25 November 2009
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: The file doesn't exist comprofilej.xml ! | Jomsocial: Disabled or not installed | UddeIm: Disabled or not installed
