This category is only for reporting defects or problems with Kunena 1.6 test versions with Joomla 1.6. This is NOT a support forum - there is no support for test versions. Users should NOT install K 1.6 alpha or beta test versions on websites with live production data.
Question Problems kunena 1.6.3
15 years 7 months ago #84385 by anonymous01
xillibit wrote: Try to install russian language pack from kunena archive
Whether it is sorry, possible - the extended answer?
What it is necessary to make?
How probably to install Russian localization?
15 years 7 months ago #84467 by xillibit
Replied by xillibit on topic Re: Problems kunena 1.6.3
Extract the russian language packs from kunena archive and install this two language packs (admin and site) with the Joomla! extension manager
15 years 7 months ago #84488 by anonymous01
xillibit wrote: Extract the russian language packs from kunena archive and install this two language packs (admin and site) with the Joomla! extension manager
In accuracy has executed your advice; has established (on a test site joomla 1.5.22) kunena 1.6.3, has taken from archive kunena-
ru-RU.com_kunena-admin.zip
ru-RU.com_kunena-site.zip
Also installed them in the normal fashion.. It does not work.
The same result.
I think, you and can make sure in it, having done simple experiment.
I remember, that similar was in kunena 1.6.1... That Russian worked, it was required in a file ru-RU.com_kunena.xml (is in archive language.ru-RU.zip) to remove this line:
<filename>ru-RU.com_kunena.tpl_skinner.ini</filename>
And installation passed ok.
Probably, here something similar?
P.S. And an another question.
At your forum I can not insert a code -
And at the forum (v.1.6.2 kunena) - I can. It too a problem 1.6.3?
