This category is only for reporting defects or problems with Kunena 1.6 test versions with Joomla 1.6. This is NOT a support forum - there is no support for test versions. Users should NOT install K 1.6 alpha or beta test versions on websites with live production data.
Question Problems kunena 1.6.3
15 years 7 months ago - 15 years 7 months ago #83806 by anonymous01
Tell, and what such with version 1.6.3? Yesterday it was updated with 1.6.2...
Result:
I can assume only, what - problems with Russian localization?
Last edit: 15 years 7 months ago by anonymous01.
15 years 7 months ago #83935 by xillibit
Replied by xillibit on topic Re: Problems kunena 1.6.3
What is your issue exactly ?
Check in joomla! languages directories, if you the languages files for Kunena
15 years 7 months ago #84086 by anonymous01
After updating with 1.6.2 - up to version 1.6.3 the result which you see on a screenshot is received. Joomla by way of. It has tried to be updated from version 1.6.3 distributed here - all has passed well. I Draw a conclusion, that a problem - in version 1.6.3 as with versions 1.6.2 and 1.6.1, as well as kunena 1.5.* similar problems did not arise.
For a long time I use kunena at the forum - there were no such problems. :(
15 years 7 months ago #84109 by xillibit
So, what is the default language in Joomla! ?
What Joomla! version do you have ?
15 years 7 months ago #84119 by anonymous01
xillibit wrote: So, what is the default language in Joomla! ?
Russian (CIS)
Joomla 1.5.22
15 years 7 months ago #84132 by xillibit
Try to install russian language pack from kunena archive
Time to create page: 0.218 seconds
