Kunena 7.0.8 Released
This category is only for reporting defects or problems with Kunena 1.6 test versions with Joomla 1.6. This is NOT a support forum - there is no support for test versions. Users should NOT install K 1.6 alpha or beta test versions on websites with live production data.
Question Upgrade error JAccess on front end
15 years 10 months ago #65984 by fxstein
Can somebody that is getting this JAccess error on Joomla 1.5.x get me an example or access to that site?
I am not sure what is happening here and need to see this. No Joomla 1.5 install should call the Joomla 1.6 classes - there is a special check built in for that.
15 years 10 months ago #66232 by Wasuup
I've rolled back my live site to Kunena 5.2.12 but will create a mirror and run the upgrade to Kunena 1.6 soon as I can for you to look at
15 years 9 months ago #71833 by Pat.Ryan
I just upgraded to 1.6.1 today from 1.5.13 and get this same error. Running Joomla 1.5.22
Fatal error: Class 'JAccess' not found in /home/xxxxxx/xxxxxx.xxx/public_html/joomla/administrator/components/com_kunena/libraries/integration/joomla16/access.php on line 113
Any solution for this yet? Do you still want to see my site?
15 years 8 months ago #79740 by mohamedplus
I would like to note that the same error still exists in Kunena version 1.6.2
Joomla Version is 1.5.22
All previous solutions do not work
15 years 8 months ago #79741 by xillibit
We have found a fix for that, this fix will be in k1.6.3, thanks anyway for report
Time to create page: 0.259 seconds
